1994 ZR1 Cold Tire Pressure
Cruising
I just purchased ZR1 replica wheels and tires to put on my LT1, 275-40-17 for the front and 315-35-17 for the rear. Question is what should normal cold tire pressure be, 30 PSI?
1994 Admiral Blue ZZZZZR1
Depends on the tires. 30 to 40psi Check on the tires themselves, there should be a recommended pressure on it. (could be higher or lower)
In the jamb of the drivers door will be a sticker with GM's pressure recommendation. I believe it is 35psi, if memory serves.
I like to run 32 32 on lt1 car and 33 32 on lt-5 car.
35 is a rough ride. Sometimes I fluctuate on long drives etc. I have an expensive tire gauge and check them quite often. Tire pressure is important for safety and longetivity. I've gotten 35-40k on a set of tires before without rotating.
The door jamb sticker tells you as long as you have right tires on car.
