Good deal?
This one has no paper trail to prove the Carfax wrong, except the lower odometer readings on all the later entries.
How hard would it be to "roll back" the odometer on one of these anyway? It's in the body control module, correct? I would think it's difficult, but nothing is impossible.
I'm not too worried that the mileage isn't actual, I'm more worried about it from a collectibility/investment/resale someday down the road, point of view.
Thanks for all the replies so far!
SHHHH!!!
I know how he does it...........
He uses a light sabre, and a little help from R2D2, or is that WD40.....
If that car has mileage in the teens, which I bet it does, as I agree some DMV clerk screwed up like they did to me, then
BUY THE CAR!!!!!!!!!!!!!!!!!!!!!!!
Stop thinking about ANYTHING else and BUY THE CAR!
There are no other things to consider unless a Kenworth rolled over it.
BUY THE CAR!!!!
Are we clear?
Let us know how it works out!
Marty
1FUNZR1
BUY THE CAR!!!!
Are we clear?
Marty
1FUNZR1
SHHHH!!!
BUY THE CAR!!!!
Are we clear?
Marty
1FUNZR1
BUY THE CAR!!!!
Are we clear?
Marty
1FUNZR1
It would take a few seconds to tell if the car had low mileage.Just a simple look at the finish on the motor will tell the story.Got any pictures?
If it looks clean, and you get a chance to have a 3rd party mechanic go through it, before you buy it to make sure there is no visible signs from repair from a bad accident don't look back while your running it through the gears at 7000 rpm
Update- I sent the seller a deposit. I'll be able to go check the car and get it either the end of this week or the end of next week.
I did get four hard copy photos. They look fine, but they don't really show anything in detail. Thanks for the reminder to check the car thoroughly for signs of accident damage... since the car was in Mexico for the first 13 years of its life, any damage would not show up on Carfax and may not have been repaired very well!
UPDATE - It's still for sale!
To update this thread: I finally got to check this ZR-1 out, and I decided NOT to buy it. I think it's a good car and I think the mileage is correct from what I could tell, but it's just not what I would be looking for.
First off, the car has been repainted, as evidenced by some overspray low in the passenger side engine compartment (not bad) and some more on the passenger side floor under the car, as well as several runs in the clear coat in hidden areas. Other than those problems that told me the car had been repainted, the paint job wasn't bad and the car looked good.
The seller did not know why the car had been repainted (he never told me about it), so that's a question, and the main reason I passed on the car. It could just have been keyed, or could be something more major?? There are no Carfax records (see earlier posts in this thread) and the title is clean (NOT salvage) so it's hard to know. I looked but didn't see any signs of crash damage, but I didn't have it on a lift and I'm not an expert.
The weatherstrip was what you'd expect for a 13,000 mile southwest car... generally very good to excellent condition, but the strips at the base of the side windows were cracked. I know that's pretty common on C4's and isn't hard to fix.
The 13,200 miles looked to be correct from what I could tell. The car had the ZR-1 solar windshield is excellent condition... no chips, no delamination. The steering wheel and clutch and brake pedals were all in good shape, if a little dirty. The interior was very nice but not perfect. Very minor wear on the driver's seat bolster, scratches on the shift ****, one of the seat controls didn't work, and a crack in one of the plastic trim pieces. But the door panels were not loose at the top, carpet was excellent (had sill protectors), seats were excellent.
The engine compartment was fairly dirty for a low mileage car, but not greasy and I don't think the aluminum was stained. The car has been sitting in a warehouse and I think they just washed all the dust off with a hose, so that made a bit of a mess in the wiper grill area in front of the windshield.
Tires were good/excellent. Some kind of Goodyear Eagles in the front, Eagle F1 supercars in the back. Rear wheels were on swapped to the wrong sides. Some curb rash on the right front wheel, I didn't notice the others, otherwise the wheels were in good shape.
Mechanically, it was generally okay but needs some work. It drove very well. Steering, brakes, clutch, transmission all felt and sounded great. The vacuum pump ran continuously so it does have a vacuum leak. The check engine light light did not come on at start up (I don't think the service ride control or service LTPWS lights came on either) and the panel on the DIC was loose so I think someone pulled the bulbs. Also there is no record of the injectors having been replaced, so that would probably be done at the same time the vacuum leak gets fixed. The seller told me he had the AC compressor replaced a couple years ago.
Since I would be looking at the car as an investment/occasional driver, I decided that the fact that it has been repainted and the lack of history was too much of a question mark for me. However, I do think that it would be a good car to fix up a little bit, and then drive the heck out of. It's just not what I would be looking for.
SO, if anyone is interested in a 13,200 mile 1990 for $13,500, this may be the car for you. The seller emailed me some pictures, but they're old scanned film pictures that have been copied into a Word document (otherwise I'd post them). I would be happy to forward them and the seller's contact information to anyone who's interested. Just PM me your email. The car is in Las Cruces, New Mexico.
1994 Admiral Blue ZZZZZR1
The keyword you said "investment" does not go well with ANY car and you should not try for that.
I have heard many times that buyers want a ZR-1 for an investment and tell them it is a bad investment.
Cars NEVER are.
ZR-1's are made for personal enjoyment and made to be driven... HARD!!!!!
David
PS I drive mine like I stole it every chance I get Permagrin
Cars NEVER are.
David
Cars NEVER are.
David
This Z is would probably be a great car with a little work; it's just not for me.
#33
#34
Not sure what you are looking for that can be had for what appears to be a very reasonable price. The condition factors seem to warrant a higher price once someone spends a day doing a good detail job on it. Good luck in your search for a better value.
#37
I'm not looking for a better value, and I'm certain I wouldn't find one if I was looking. I had never seriously considered owning a ZR-1 and I was not looking for one, but this car came up because it belongs to a relative of a co-worker. If anybody is interested it can be bought for $13,500.
#38
#39
Even in the condition you say it's in it's still a good deal and like was said with some detailing it could sell for more. Wish it were closer I may think of buying it and reselling it. JFYI C4's with that kind of mileage sell for that here in Iowa.
#40
Got it!!
Well, I was able to make a deal on this Z for considerably less than the $13,500 so it's now in my garage! Below are some pictures I took after a quick wash. I haven't touched the engine yet.
It's not perfect but I'm happy! I've reconsidered my opinion on the repaint too... I think you guys may be right, it's factory overspray. It's on the underside of the car, but there's absolutely none on any weatherstrip, wiring, molding, suspension, etc. so I think it's factory.
The plan is to get it running properly, then fix the minor cosmetic issues.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
