Paper weight?
The 90 is prone to the clutch switch going bad, try to bypass it
Did you wash the motor? if so replace the starter.
Will it push start? if so starter
Hope this helps
it happened to mine 91 it would start cold, drive it a little and sometimes it would not start, replaced the starter 7 years ago and all well now
Good Luck
But here is what I suggest you do. The next time it doesn't start. Push start the car. After the engine fires up, look at the speedo console. Is the SECURITY light on? If it is then you have an ignition switch problem or Bubba has cobbled up the wiring maybe by adding an extra anti-thief, custom stereo or other extra electrical something. If he did, get rid of that junk first!
Try your spare key first that might work, those chips on the key can go bad some kind of way.
This is what happened to me, I kicked, cussed and was ready to burn the damn thing to the ground until one night after push starting I noticed the SECURITY light on. I didn't have any Bubba add-on s. Brought car to Chevy dealer had them change the switch and haven't had that problem in five years.
Good luck
CJ
When did you fix these items and when did you start having problems?
Do you see a security light when you open the door?
Do you have a spare set of keys?
Have you posted up or seen the club forum / website? www.zr1netregistry.com and http://www.zr1.net/forum/
David
If the magnet is not epoxy impreganted/coated well, it will fail from too tight of tolerences due to swelling.
Just push start next time and eliminate that as the problem.
12 volts from the ignition switch when in Start mode
goes to a Yellow wire at the Starter Enable relay.
At the same time, the CCM grounds the Black wire at the
Starter Enable relay if the key pellet resistance is correct.
Relay closes and 12 volts passes thru the
relay and out on the Yellow/Black wire that
goes to the Clutch Safety switch.
12 volts passes thru the Clutch Saftey switch
to a Purple wire which goes to the Starter
Solenoid.
Note: The Purple wire at the Starter Solenoid is a push on
Spade lug connection. Some people replace the connector
with a ring lug type connector.
The Starter Enable relay is located below the dash cluster.
If the starter doesn't engage and the key pellet value
is correct, you should still hear a faint click from the Starter
Enable relay when the ignition key is in the Start position.
If you don't hear a click, the relay could be bad or the
CCM is not grounding the Black wire.
Using the wiring diagram in the last post sounds like the best way anyhow
You'll find it directly. Keep us informed as you go. Good luck,
P.
Maybe I can put a fan with a humidstat.. but still the moisture / starter issue ? I dont want a nice car and come back and have issues. Thanks
It's when someone power washes the engine or steam cleans it, that moisture gets onto the starter. This "could" cause the starter to have issues.
