C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Ignition modules.
Old Mar 10, 2013 | 08:21 PM
Tyler Townsley's Avatar
Tyler Townsley
I have (and you can buy) a dis checker. I used it to check out Brits car before we started it last fall (his dis module was in fact bad even though it had come from a running car). I had a prototype dis module that was ok up to 400 rpm but fell apart after that, it took the checker and a scope to find that out (and 2 years of troubleshooting on my part because nobody knew anything about the early cars). I have not found any dis modules made for the first 25 88 cars to be good. they have all failed. In looking at dis modules make sure you know your stuff, if you get a used one that was in an 89 and try to use it in a 90+ you will destroy your dash instruments. You can run it buy you will have to rewire the inputs.
Tyler
