Hi does anyone know if ignition modules can be rebuilt or tested. I have a spare one that looks like the small screws have been unscrewed at some point, leading me to think it has failed at some time. Thanks.
No it can't. It's epoxied internally. Really no way to take stuff off components. Done for shielding and heat.
I did try it out on the car and it started but didn't run well, so put my original back on.
I know very little about ignition modules and thought I would enquire about it. Also heard they are hard to come by and before I throw it away wanted to know if they are rebuildable.
DIS Modules are difficult to find, usually. Good to have an extra if you can find it.
That's what I've been hearing Vette Daddy. I'm building up a spare LT5 I've got and was hoping to make use of this one, if they were rebuildable, which they're obviously not. I'm in no hurry, so will keep an eye out for one at a later date.
There are actually two part numbers for the LT5 also. What is the number that is "INKED" on the one that you have? I would not just toss it. The information from the one that you're using and the one that you've got as a spare would/could be of importance to the fact that it ran but ran poorly. An early one requires a substantially different air gap at the crank sensor than the later more popular DIS.
Great point. If it was fried, I doubt motor would run at all or even start.
I didn't mention the "running poorly" but the OP mentioned it ran well with his other! We don't know which the car needs, which he attempted or if his are actually matches (2 of the same). The early is mentioned to only be in the 1st 500 builds but my '90 #653 has an early DIS. I've no reason to suspect it's NOT the original but I have NOT checked for shims at the crank sensor either. I put 20K problem free miles on it. The #1103841 I understand isn't nearly as sensitive to air gap but I certainly can't attest to that as fact.
I believe even a bad one if it was confirmed to be bad could be a good "diagnostic tool" - if the DIS exhibited the same run characteristics on every engine it was installed on but it eliminated a particular issue that the engine being diagnosed exhibited then I guess you could assume you've maybe found something that needs to be addressed. Make sense?
My mistake : I thought you were talking about ignition coils, not the DIS module. The DIS module is rare as hen's teeth!
