C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
speedo stopped working
Old 02-21-2018, 11:18 AM
oldpro
oldpro's Avatar
Default speedo stopped working
was driving along and all of a sudden my speedo stopped working . it just reads zero . is there a way to trouble shoot this ?????
Old 02-21-2018, 12:14 PM
biggiefl
biggiefl's Avatar
Let out the clutch and give it some throttle
Old 02-21-2018, 12:22 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
Speedometer shows zeros
oldpro (02-21-2018)
Old 02-21-2018, 09:02 PM
Goldcylon
Goldcylon's Avatar
if its not the variable Speed Sensor or its connection and it turns out to be the speedo I highly suggest http://batee.com/ as he can service the unit. GC
Old 02-21-2018, 11:32 PM
wfot
wfot's Avatar
Look over the connections really well. I had this problem last summer and ended up assuming it was the sensor. Someone who changed the clutch mangled the wires and did a hack job patching them, there are only 2 thin wires. The connector looked good and i had to follow the wires about 12 inches from the yrans to find the damage.
john
5abivt (03-01-2018)
Old 02-22-2018, 09:31 AM
ccmano
ccmano's Avatar
Looks like u got her running Bradley! Congrats. Yup, only possibilities are the sensor and gear at the back of trans. It’s connection and wiring. Or the speedo itself. Batee.com is the place for speedo repairs.
H
Old 02-22-2018, 10:07 AM
Demps
Demps's Avatar
As others have said. Follow Cliff's link in red. Here's some personal experience...continue until you find the culprit.
1) Make sure cluster powers up.
2) Check wire connections on VSS in transmission.
3) Remove the VSS and attach the 'shaft' to a drill...have someone monitor speedometer with acc on while you spin the drill/VSS--speed doesn't register=VSS possibly bad; speed does register=gear on tranny 'shaft' may be slipping.
4) Reach in vacated VSS hole and locate gear. Try to rotate then slide gear on 'shaft'. If it moves, secure it with its circular single prong clip. You may find the prong extension is not positioned correctly or enough offset. I removed drive shaft to resecure clip on/in gear.
Ted
Old 02-22-2018, 10:44 AM
oldpro
oldpro's Avatar
guys thank you so much soon as I gets a little warmer today I will jack her up and go to work cking things out and report back
Old 02-22-2018, 11:54 AM
ccmano
ccmano's Avatar
Glad you have good weather. Snowing here. I know the locking tab for the connector on my speed sensor is broken. If the rest of the speedometer cluster is working it’s more likely the problem is at the sensor.
H
Old 02-23-2018, 12:09 PM
oldpro
oldpro's Avatar
sort of good weather 30 in the morning and 50 high too cold for me right now going to wait till sunday when it is suppose to hit 60.
To speedo stopped working
Quick Reply: speedo stopped working
