Does anyone know whether I can use c-6 stock wheels on my c4 zr1? THANKS FOR YOUR HELP
I am about to put C6 ZR-1 brakes on my car. I am going to install C6 ZR-1 wheels while I order new wheels to fit the brakes. In my research I see that the only problem is in the rear. Supposedly the tire/wheel hits the exhaust and you have to use a space.
Yes I put c6 wheels on my 1992 c4.
the only thing I had to do was get spacers for the rear. The ones I used are 1+1/4 " thick. I got my information from here on the forum now I pass it on . Good luck and enjoy.
Are you saying the spacer is 1/4 inch or 1 1/4 inch?
Only knowing the width and offset specifics of the wheel you're intending to use can get you 'valid' information. "Can use' and 'will fit' is something that if you're not familiar with wheel offset etc you don't need to be 'speculating'. There's certainly been some 'WAG ' mentioned already in the thread.
