read afr
Old Feb 9, 2005 | 09:15 PM
MRC5's Avatar
MRC5
Default read afr
here my c5 AFR
idel = 15
full throttle =10.5
what do ya think ? should i do some advance ?
Old Feb 9, 2005 | 10:16 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
How are you reading your air fuel ratio? Wide band O2 or stock O2 sensors?
Also, are you reading that AFR on the dyno or on the street?
10.5:1 seems really rich. How many degrees of timing are you running right now?
Old Feb 10, 2005 | 01:48 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Old Feb 10, 2005 | 03:18 AM
MRC5's Avatar
MRC5
I'M READING AFR BY WIDE BAND O2 . ON STREET . I PUSH THE CAS FROM 20 MILE FULL THROTTLE TO 144 MILE . THE WIND BAND SHOWS 10.5.
WHAT IS THE BEST ARF NO. FOR MORE POWER AND SAFE DAILY DRIVE ?
Old Feb 10, 2005 | 06:23 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
10.5 isn't that bad and surely is safe.I run mine at
11.5-1 at 3000rpm
11-1 at 4500rpm
10.5-1 at 5000+ rpm
I think my track times speek for themselves
Old Feb 10, 2005 | 09:00 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Well, again, IIRC you blew something in your motor last time? So maybe 10.5 is a nice safe number for you as Slowhawk indicates. You can probably get away with being leaner in the lower RPMs to generate more power, but that's a broad generalization I'm making. You really should do some data logging/tuning/testing to determine what your optimum ratio/timing setup is.
Old Feb 10, 2005 | 03:19 PM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
I would lean it out a bit and it will probably work a little better for you. On the other hand, I wouldn't be too crazy about 15 at idle either.
Old Feb 10, 2005 | 03:35 PM
IM QUIKR's Avatar
IM QUIKR
MRC5,
I was following the previous threads about the dead motor when you got into boost, but never heard what blew on your motor. What exactly went wrong?
Matt
Old Feb 10, 2005 | 03:51 PM
BlackMagicC5's Avatar
BlackMagicC5
Originally Posted by IM QUIKR
MRC5,
Matt
Old Feb 10, 2005 | 04:26 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
MRC5,
Matt
May have been my mistake, I thought I remembered something breaking in the motor. Maybe I am getting senile in my age.
Old Feb 10, 2005 | 04:31 PM
MRC5's Avatar
MRC5
MRC5,
Matt
reduce of fuel killed the motor . i ran the car with low fuel in tank .for that reason i got the detonation in two piston .
i rebuild the engine but with stock bottom , the car run great now .i race every weekend . i'm so happy with procharged .
today i went to the track in first time
first run stock tire .
1/4 13.8/188.13 km
60' 2.5
1/8 9.5
2ed run stock tire
1/4 12.28/195
60' 2.2
1/8 8.1
next time i'll run nitto tire and do some tune .
To read afr
