Window switch
Old Feb 24, 2005 | 09:24 PM
Venom2000's Avatar
Venom2000
Default Window switch
I am installing my rpm window switch. Where is the pcm and what wire do I hook it too?
Old Feb 24, 2005 | 09:44 PM
ICULUKN-C5's Avatar
ICULUKN-C5
PCM is under your battery. To get to it remove the passenger side front wheel and remove the inner fender well. What wire will depend on what year your car is. You can also get the tach wire under the steering column.
Old Feb 24, 2005 | 11:17 PM
Venom2000's Avatar
Venom2000
It is a 2000 c5
Old Feb 25, 2005 | 08:31 AM
RoadRebel's Avatar
RoadRebel
If its easier you can catch the white wire under the dash on the drivers side. its wrapped up just tot he left of the steering column.
Pin 10 on the PCM if you want to catch it under the hood.
Phil
Old Feb 28, 2005 | 12:55 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Phil
Here are the instructions for finding that white wire under the drivers side dash
http://forums.corvetteforum.com/showthread.php?t=619162
To Window switch
