methanol injection ?
Old Mar 14, 2005 | 04:07 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default methanol injection ?
How long does your tank last?
Did you have to relocate your battery?
Where do you buy methanol?
Old Mar 14, 2005 | 05:10 PM
3XBlack6spd's Avatar
3XBlack6spd
You can use your windsheild washer resevoir as the Tank, so no you don't have to relocate the battery, and I believe you are actually referring to Alcohol injsection, Some people mix it with water and call in methanol I guess, but you can buy denatured alcohol at any hardware store, or have a fuel distributor ship you some, but you will most likely pay a lot more that way.
hope that helps.
Old Mar 14, 2005 | 06:32 PM
TANGLVR's Avatar
TANGLVR
Methanol is a specific type of alcohol and reported to be the best to use in alky injection for both its cooling and power adding properties.
Straight meth is mostly recommended...you can mix with water if you like
Old Mar 14, 2005 | 07:53 PM
Geneus's Avatar
Geneus
CH3OH...methanol, as opposed to CH3CH2OH...ethanol...better to drink!
Old Mar 14, 2005 | 08:04 PM
auctiondepot's Avatar
auctiondepot
Methyl hydrate (also called methanol, methyl alcohol or wood alcohol) is a colourless liquid with a light alcoholic smell that sometimes has a colouring agent added to it. It helps prevent freeze-up during winter months.
Old Mar 14, 2005 | 08:50 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Do you know if there's any problem with evaporation if you use straight methanol? Just curious.
Old Mar 14, 2005 | 08:59 PM
TANGLVR's Avatar
TANGLVR
None concerning storage of it as it's in an enclosed container (mostly closed...vented to relieve pressure).
And actually in it's use the evaporative properties can be beneficial when it's injected as it will atomize far better than when mixed with water and even if there's some spillage to a small leak it's best that it evaporates before it combusts.
Old Mar 14, 2005 | 09:13 PM
jmzvet's Avatar
jmzvet
I have a methanol/water injection system and mix it 50/50. I use the windshield washer tank so I can still use it to wash my windshield if necessary. I buy the methanol at a local race shop for $5 a gallon and go through about one tank of meth/water to every tank of gas depending upon my driving style.
Old Mar 14, 2005 | 10:39 PM
chrislee2's Avatar
chrislee2
Cruise-In II Veteran
Cruise-In V Veteran
How well does it work as a washer fluid?
Old Mar 14, 2005 | 10:56 PM
jmzvet's Avatar
jmzvet
The blue washer fluid is anywhere from 1% to 30% methanol so it works just fine.
To methanol injection ?
