ATI or Vortech?
Old Mar 28, 2005 | 11:09 AM
Rob P's Avatar
Rob P
Default ATI or Vortech?
What are the differences in power and performance?
I have a pretty much stock 99 M6. Is it safe to charge the car at 60000 miles?
Old Mar 28, 2005 | 11:28 AM
mdhmi's Avatar
mdhmi
Sure. Might want to do a compression test first.
Both Vortech and ATI make nice head-units. I'm partial to the ATI as it is self oiling and seems to have a much larger install base, at least on this forum.
Mark
Old Mar 28, 2005 | 11:54 AM
Rob P's Avatar
Rob P
I am leaning towards ATI myself but my friend just bought the vortec and I read up on the estimated numbers and it is pretty equal to the ATI.
Is the install difficult on the ATI? I would like to attempt the install myself.
Old Mar 28, 2005 | 12:27 PM
mdhmi's Avatar
mdhmi
I would say the install of the ATI is a little easier as you don't have to drill the oil pan.
Mark
Old Mar 28, 2005 | 12:37 PM
Sportsdude's Avatar
Sportsdude
I went with the ATI setup but the Vortech is also very nice.
Old Mar 28, 2005 | 02:04 PM
BlackMagicC5's Avatar
BlackMagicC5
I think performance would be pretty close. ATI is probably easier to install because you don't have to drill the oil pan, like said earlier. I think it basically comes down which one you think looks better.
Old Mar 28, 2005 | 02:17 PM
George8211's Avatar
George8211
Which one makes the most noise ??
Lets face it... not many people are going to see you race (so i think the stealth thing is over rated)... Might as well let it be heard... and turn some heads.
Old Mar 28, 2005 | 03:57 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
From what I hear the Vortech is louder, even the quiet trim version.
Old Mar 28, 2005 | 04:19 PM
3XBlack6spd's Avatar
3XBlack6spd
If you want to hear it, check out the video links in my sig. Needless to say, mine is not the quite version!
Old Mar 28, 2005 | 05:30 PM
Bigben's Avatar
Bigben
The Vortech is much quieter if you get the SQ-trim. I can barely hear mine unless it is at idle and the Vortech Kit has a completely legit EO number if that matters to you.
The ATI kit has been improved upon greatly by some of the Vendors on the Forum (AA corvette & ECS).
Can't really go wrong with either, but as a Vortech owner I can say that
The larger user base of the ATI has resulted in a more refined blower setup than the Vortech kit.
I feel like the Vortech has a little more torque on the low end, but a little less upper end HP than the ATI.
Old Mar 29, 2005 | 09:52 AM
Rob P's Avatar
Rob P
thanks for the feedback.
What about installing? Is it really difficult to install?
Old Mar 29, 2005 | 03:05 PM
Mike04's Avatar
Mike04
Here is an install link to check out.
http://www.superchargers4less.com/c5/#Vortech
Old Mar 29, 2005 | 03:35 PM
Z06 Tom's Avatar
Z06 Tom
I've been very happy with my Vortech. Other then some early belt problems, it's been a great system. My Z's at Dynotech right now getting the T-trim upgrade and a set of AFR heads. Should be around 650 at the wheels when it's done.
Before the latest round of mods:
A few install shots:
To ATI or Vortech?
