3 Bar Question
Old Apr 5, 2005 | 01:34 PM
lplott's Avatar
lplott
Default 3 Bar Question
Dummy question: What is the 3 bar that has been floating around here lately?
Now yawl know how really stupid I can get...
Lonnie
Old Apr 5, 2005 | 01:43 PM
DDSLT5's Avatar
DDSLT5
Lonnie
I believe they are referring to a 3 bar MAP sensor. Manifold Air Pressure sensor that can measure boost up to 3 bar.
Old Apr 5, 2005 | 01:58 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Or, it could be the measure for injectors. For example, most injectors are rated at 3-bar (43.51 psi), but the ls1/ls6 operate at 4-bar (58.02 psi). So, a 2001 and up ls6/ls1 GM injector at 3-bar is 24.7lb injector, and at 4-bar it's 28.5lb injector. There is more if you want/need. By the way it's not a dummy question, just means you want to learn as all of us have.
Old Apr 5, 2005 | 02:44 PM
kromberg's Avatar
kromberg
The MAP is really only 'important' in tuning Speed Density Mode tunes. If you are tuning via the MAF sensor, a 1 BAR MAP sensor is perfectly fine. A MAF tune sets the A/F ratio via the PE vs RPM table when the MAF sensor is maxed out.
Keith
To 3 Bar Question
