Boost Controllers
Old Apr 6, 2005 | 04:44 PM
mdhmi's Avatar
mdhmi
Default Boost Controllers
Just a few out of curiosity questions:
1) If you only plan on running at a single boost setting (say 9 #'s) is there anything to be had by running a Blitz boost controller (other that displaying your AFR via a WB) ?
2) If you already had a boost gauge, could you use both the Blitz and the normal boost gauge ?
Thanks,
Mark
Old Apr 6, 2005 | 04:53 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Thanks,
Mark
mark it has a limiter built in and will flash red and an audiable beep goes off. when it detects overboost itll back of the boost levels by a preset percentage. example you can set limiter to drop boost 15% below peak.
another feature is it controls the speed in which the waste gate open.
BAMM!!
Old Apr 6, 2005 | 06:07 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Here's a link of a great boost controller, I have installed a ton of them.
Keep it simple and stupid.
http://www.blitz-na.com/Blitz_Boost_Dsbc.htm
To Boost Controllers
