max boost level?
Old Apr 9, 2005 | 08:21 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default max boost level?
stock displacement, forged, afr heads, 8.4 compression, 94 gas and L19 head studs. what psi do you think?
i understand there are lots of variables but take a guess. oh yeah 97 lines speed inc rails and reg. and lpe and msd bap w/60 motorons.
i dont think that fuel will run out before the octane will. right?
Old Apr 10, 2005 | 12:35 AM
AVB's Avatar
AVB
octane will be less of an issue w/ alky Nick.. also, some have gone incredibly higher in boost with it.
w/o alky 18 maybe 20 if you don't run out of fuel and go w/ bigger injectors. w/ alky, capable of 5 more.
That's my guess.. only a guess.
Old Apr 10, 2005 | 11:15 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Hey Nick,
I don't know what the max boost level is going to be, but it will at least be 20. I installed my switchable boost controller yesterday...obviously I haven't switched it to on yet..not until I do the re tune down at Andy's on hi octane. It is a simple switch next to my gear shift. Off is the 9lb setting, 16-17lbs will be the ON setting. If the thing works like it should, I am going to be very happy with the controller. It has a little locking ****/dial that I mounted under the hood. You move it clock wise to increase boost 0-15lbs.
Your compression ratio should allow you to use 91 octane up to a maximum of 12lbs of boost.
Old Apr 10, 2005 | 06:36 PM
NICK YOSKIN
St. Jude Donor '08
Originally Posted by Shinobi'sZ
Hey Nick,
kevin the 3 extra octane points from 94 should see a 1 to 2 pounds i'd imagine.
also i need to make up my mind if i am going w/hp sd 2 bar. i intially wanted 3 but not sure if itll be ready in time. i dont own ls1 edit so i really cannot reflash if i wanna run higher boost, tuner not around the corner. give me some ideas
To max boost level?
