Yep. Last I heard there was a two week delay on shipping.
I'm probably going to call them next week.
Mark
mark i bought last night, hp 2 bar and enhanced io. with lc1 itll log wideband in their histogram, nice. sure any wideband will log but its nice to have it in the same program as the editing, cut and paste now i need to know the pin in the ecu for spped sensor for my speed control from blitz
I can't find much info on the LC1, but if there's a shipping delay you might consider going with the Zeitronix ZT-2. I have this unit and love it. I think BLOWNZ06 is also using this unit.
Right now I just have RPM and AFR hooked into the controller, but my boost sensor is on order and should be here soon. The unit works great with the LCD screen you can buy separately, or if you have a laptop, with their datalogging software (free with the controller).
At $279 for the basic setup (controller, harnesses, Bosch WB O2 sensor) it's a pretty good deal. Add another $109 if you want to log boost in correlation with AFR and RPM.
(btw, the ZT-2 does have analog outputs to hook into other engine management systems or boost controllers with analog inputs)
