worthwhile to intercool a magnuson?
Old Apr 28, 2005 | 03:04 PM
Derry's Avatar
Derry
Default worthwhile to intercool a magnuson?
I have an '03 with a Doug Rippie Motors top end package and a magnuson that is set at 5psi. I am in the northeast and drive it mainly in the summer but it is usually in the 70's temperature wise. Is it worth the $1500 plus for the intercooler kit?
Old Apr 28, 2005 | 03:08 PM
AVB's Avatar
AVB
I would do alky injection.. do a search and you'll find posts w/ non i/c'd mags on alky getting the same power as the intercooled version w/ alky.
and it's $700-800 less..
Also, w/o alky you'll never be able to run a 2.8/2.9 pulley.. which, is what your able to do with it i/c'd or not...
Old Apr 28, 2005 | 03:19 PM
Geneus's Avatar
Geneus
I'd call Doug Ring at ECS and discuss it with him. ECS sells a very nice, DIY turnkey alky kit which will make you and your Maggie happy!
Old Apr 28, 2005 | 03:22 PM
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
Old Apr 28, 2005 | 03:48 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
What am I, Chopped liver
Old Apr 28, 2005 | 04:00 PM
wrustywrench's Avatar
wrustywrench
no,,,,,go with Alky, call chris....keep from thinking he is liver
Old Apr 28, 2005 | 04:05 PM
Geneus's Avatar
Geneus
No,...he just gives better phone than you.
Old Apr 28, 2005 | 04:50 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
That's not allowed right now Chris being it's Passover.
Old Apr 28, 2005 | 04:56 PM
BlownV6's Avatar
BlownV6
How big is the Core with the Maggie kit?
Old Apr 29, 2005 | 12:32 AM
SaltyNuts's Avatar
SaltyNuts
But couldn't you run more boost with intercooled + alky than non-intercooled + alky?
Thanks.
Old Apr 29, 2005 | 12:49 AM
BlownV6's Avatar
BlownV6
Thanks.
The Eaton canisn't great when it comes to airflow. One of the reasons why everyone wants a kenne bell twin screw.
Old Apr 29, 2005 | 12:20 PM
AVB's Avatar
AVB
Thanks.
The intercooler is good for cooler air temps when not in boost or when not spraying alky. There's a benefit driving around city streets or cruisin.. but not sure when it comes to making power at the top.
Old Apr 29, 2005 | 02:16 PM
Derry's Avatar
Derry
I can see where it would not help power much on a cool day but wouldn't the i/c help the power on a warm day?
Old Apr 29, 2005 | 02:36 PM
AVB's Avatar
AVB
With an intercooler on a hot day you'll eventually start getting heat soaked and drop power.. much later than non i/c'd i would imagine gets hot almost immediately, since I only had the i/c'd version.
i/c or no i/c, w/ alky you reduce the effect of heat soak and therefore see no or very little drop.. and again only on hard acceleration or boost.
Old Apr 29, 2005 | 03:54 PM
M_T_0's Avatar
M_T_0
I'm going I/C but I live in central Texas and it gets to 110 here in the summer. with you being in the NE and if you can get a non i/c mag then go for it, run AI and have fun. the I/C is needed down here IMO but you can make as much hp or more with a non-I/C with the right AI setup and tuning.
More Than Zero
To worthwhile to intercool a magnuson?
