HP tuners 2/3 bar SD setup
Old May 2, 2005 | 12:09 AM
QuickSilver2002's Avatar
QuickSilver2002
Default HP tuners 2/3 bar SD setup
Is anyone here running a SD tune with the HP tuners 2/3 bar option? It has been out for a while, but I have not heard much about it.
Old May 2, 2005 | 12:18 AM
Skunkworks's Avatar
Skunkworks
Wondering same thing, all I heard was Speed Inc. had good results with 3 bar version. I don’t know if drivability is an issue, but allot of current turbo models run SD.
Old May 2, 2005 | 12:34 AM
QuickSilver2002
Drivability should actually be better. I just seems a bit expensive and I want to make sure it is working for others before blowing the cash.
Old May 2, 2005 | 12:47 AM
Skunkworks's Avatar
Skunkworks
Strictly theoretically speaking, running of MAF sensor should be superior to speed density. As far as I understand it, MAF also runs cleaner and more reliably then SD.
But from a FI aspect, SD is the way to go, especially since most C5 MAF sensors max out before peak RPM/boost is hit.
Oh, I think it really comes down to experience, most tuners really have LS1Edit nailed down and there may be a comfort factor associated with it.
Old May 2, 2005 | 08:45 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
i am or i should say will be. i have all the parts, also upgraded enhanced io too. i received my lc1 innovate wide band. my car will be a moving tuning shop
guys on the ls1tech board are running mafless
Old May 2, 2005 | 08:49 AM
NICK YOSKIN
St. Jude Donor '08
YES! and money too!!!!!!!!!!!!!!
Old May 2, 2005 | 09:32 AM
J-Rod's Avatar
J-Rod
If you had a MAF that could keep up, perhaps that would be the case. But, if you look at the aftermarket systems out there, all of them are SD. If MAF were superior I'd think you'd see them in action.
I've tuned in SD. After doing so, I'll never go back to MAF tunes... My buddy Pete is running the 2/3bar SD stuff. Works like a champ...
Old May 2, 2005 | 09:55 AM
mdhmi's Avatar
mdhmi
What is the cost, approximately, in switching over to the 2/3 bar stuff? Also, in summary, what difference would I _notice_ ?
Thanks,
Mark
Old May 2, 2005 | 11:09 AM
NICK YOSKIN
St. Jude Donor '08
J-ROD NICE TO SEE YOU HERE!!!!!!!!
as you probably know i have 2 bar w/enhance io. i should have my 03 c5 a/4 forged 8.37 compression ptk 03 c5 running shortly. keith told me he wasnt sure when 3 bar was going to be complete. ill upgrade when it's out.
mark cost me $950 for hp edit enhanced io and 2 bar option.
Old May 2, 2005 | 11:13 AM
NICK YOSKIN
St. Jude Donor '08
Thanks,
Mark
mark i had neither ls1 edit nor hp so the way i am looking at it it cost me, 150 enhance io 290 for 2 bar..........not bad.
Old May 2, 2005 | 11:24 AM
QuickSilver2002
Yea, theory and the real world are two totally different things. MAFs work great in a steady state, but the current hardware simply can't react smoothly to rapid change. In fact, the PCM uses a combination of SD and MAF during most throttle transitions because the MAF is not reliable in those conditions. This is mainly due to the fact that the MAF is on the wrong side of the TB.
I've never done an SD tune on an ls1, but everyone who has claims the smoothness of the motor is greatly improved. The Australian guys have been doing it for years and there is actually an ls1 based Holden that comes from the factory without a MAF.
I know SD is good for a highly modified setup, I'm just wondering if the HP tuners implementation works as advertised without major bugs. I'm pretty sure they tweak the PCMs operating code for the 2/3bar mode and that is very different from just calibrating the PCM.
Old May 2, 2005 | 12:14 PM
Shinobi'sZ's Avatar
Shinobi'sZ
I have a contact for SD tuning with HP 2bar and waiting for the 3bar, if Andy had his Load Cell installed when I was down there (load cell on the way) I would have done a SD tune with the new MAP sensor. I would also need the 3bar HPtuning software, because I would be pushing over 14.7lbs of boost (2bar max).
The contact I have is out of Australia and has helped JRod and a couple of others. He even offerred to come to California to help out but told me he could give me all the information and files over the internet. His partnering business is out of Texas and he uses a phone number from there..pretty cool I can call Texas and talk to Australia. Anyway, its just a matter of time until run SD 3bar with a Wide Band monitoring everything.
Old May 2, 2005 | 03:57 PM
QuickSilver2002
I'm assuming this guy is charging for service. If so, can you post the contact info? I'm probably going to try this the hard way, but I may end up needing some help.
Old May 2, 2005 | 04:18 PM
NICK YOSKIN
St. Jude Donor '08
i'd like to find tuner that is fimilair w/sd tuning in the pa nj.
Old May 2, 2005 | 05:14 PM
Skunkworks's Avatar
Skunkworks
I agree with response time to large step change. Maybe my past experience with turbo running SD (non LSx) has left me a bit biased and not in a good way.
In the industrial controls world we use mass flow transmitters as much as possible to close loops. It removes allot of variability that can be associated with trying to calculate mass based on multi-sensor feedback (cumulative error). This is not C5 related, but can see maintaining AFR being easier with MAF.
I’m probably a month or two from installing a supercharger on my car and now considering letting Speed Inc. do a SD tune.
If you decide to go SD, keep us posted and good luck.
I’m new to this forum, there is wealth of knowledge here and enjoying it!
Mike
Old May 2, 2005 | 09:19 PM
Shinobi'sZ's Avatar
Shinobi'sZ
I am going to PM you, he was looking for somebody to work with I think. He PM'd me.
Old May 3, 2005 | 02:24 AM
Textralia's Avatar
0Textralia
Former Vendor
Yep, I've been running two bar with HP for quite some time as a beta tester. It works great! It's a comforting thought knowing what ever the RPM and boost level is, the fuel is just where you asked for it. Especially with turbocharged applications.
Pete.
To HP tuners 2/3 bar SD setup
Old May 3, 2005 | 09:53 PM
NICK YOSKIN
St. Jude Donor '08
The contact I have is out of Australia and has helped JRod and a couple of others. He even offerred to come to California to help out but told me he could give me all the information and files over the internet. His partnering businesUNE I as is out of Texas and he uses a phone number from there..pretty cool I can call Texas and talk to Australia. Anyway, its just a matter of time until run SD 3bar with a Wide Band monitoring everything.
I SEE!!! KEVIN I SPOKE TO PETE FOR 30 MINUTES THIS MORNING.
kevin i guess you already know that i spoke w/pete. so what do you think? ill send him my bin and he'll send base map, should be able to tune over phone but still need dyno facility, he said he might make his way over to ecs when he's in the states(JUNE I BELIEVE)
Old May 4, 2005 | 06:45 PM
mdhmi's Avatar
mdhmi
So if you are going to run under 14.7 pounds of boost SD isn't necessary?
Mark
Old May 4, 2005 | 07:47 PM
Hool97's Avatar
Hool97
The question remains how smooth can they make the grid or how finely can you control the SD mode in a 3bar system with the stock computer.
I am waiting to see their 3bar system in action and on paper.
