We tried a pull @ 14 and the dyno wouldn't hold the car.
Doug is going to change the tires for a 14 and 16 psi pull.
Doug is a master and Chris isn't too shabby himself.
Mark and John also had a hand in this build as well too.
Thanks again to Phil RoadRebel for his input.
ECS as I've always said is the best
If you guys have any questions on this build you'll have to contact ECS direct as I've been sworn to keep tight lips as there are a number of one off items in the car.
Nice numbers. Is your TTi kit running out of steam at 5000 rpm too? Looks similar to the dyno roadrebel posted the other day, but the detail on the sheets is a little hard to see.
Big power Care to elaborate more on the TTix kit ? Is TTi , Turbo Technology's kit ? What size turbos ? Pump gas with alky or race gas ? Good Luck hooking that power with a manual trans . Any plans to run it down the 1/4 ?
These dyno sheets are on fresh engines, from reading Phils comments they have not put any timing in up top yet.
It will be interesting to see what happens when they start to tune a bit more agressively after the engines are broken in.
Congrats Jersey Jay!!! Those numbers are great!!!
That is what I call a Torque Curve!
Turbo Tech Kit TTiX
93 pump gas
Spraying 2% meth on 11 psi
Spraying 4% meth on 12.8 psi
Turbonetics T3/4 hybrids
I'm sure ECS will figure out what is going on in the upper rpms ranges. It is good to see the scaling the same for hp/tq. Nice preliminary numbers.
