NX problems
Old May 21, 2005 | 09:46 AM
GTrain's Avatar
GTrain
St. Jude Donor '14
Default NX problems
Need help from the NX experts. Sorry its an LT1, but you C5 guys may be able to help.....
Had the car at the track last night and it didn't run well. I have 150 system, but only a 75 shot set up on a 96 LT1 in an Impala SS, Walbro fuel pump, Mallory 685 ignition and WOT switch.
I really "felt" nothing as far as boost on the track. Usually I can feel it, but couldn't last night.
Track seemed ok, but hot at race time (107 Degrees).
I refilled the bottle about 6 months ago and only sprayed once at the time to test it, then the car, and the bottle sat hooked up in the trunk.
I figured I had a full bottle, but once I got to the track last night, I really had to sit on the purge to get any No2 to spray out. It finally did, but not much. Bottle pressure was in the green.
I made three runs and the bottle pressure didn't budge. Usually after a run, it will drop down some, but last night nothing, after runs it didn't change.
Symptoms:
A. Slow times (non no2 times)
B. Old bottle
C. Purge takes 4 or 5 long bursts to get some no2 (not much)
D. No change in bottle pressure after runs
Should I stop and take the system apart to test it or is this an old bottle problem ?
Old May 21, 2005 | 10:33 AM
maticam's Avatar
maticam
Do you have a bottle heater on it????
Old May 21, 2005 | 11:21 AM
GTrain's Avatar
GTrain
St. Jude Donor '14
I do, but it was off. At race time, it was so freakin hot outside, the bottle was too hot and the pressure gauge was in the red. So we waited for it to cool off, and once it was in the green, I used it. Pressure didn't move all night....
Old May 21, 2005 | 12:19 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Go get a fresh fill. You may have lost some n20 through it sitting. The valve is only so good under pressure. Do you have a filter? That may be clogged too since you have some bottle pressure. Just a stupid question but are you sure the bottle was all the way open...
Old May 21, 2005 | 12:25 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Hey glen....
Yeah it was all the way open. I was at firebird last night trying it. After the second crappy run, we all huddled to look at the car and it was open all the way.
I do have a filter and will install a new one today. I am going to do a fresh fill as well, but I am going to check everything today and try again.
Old May 21, 2005 | 08:13 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Update:
All connections were fine. Bottle seemed full and purged better when it cooled off some more today. Took the lines off and tested to see if it would spray. It wouldn't.
Tested the electrical and found no power was getting to the WOT switch. Traced it back and found a wire had come loose.
Retest and all is good !
Old May 22, 2005 | 02:46 PM
ICULUKN-C5's Avatar
ICULUKN-C5
when you going back to the track..
Old May 22, 2005 | 04:21 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Looks like June 3 is the next friday drag night. I will refill the bottle and see what my SS can do.....
Old May 22, 2005 | 11:59 PM
Eric Hawkins's Avatar
Eric Hawkins
How reputable is the place you had the bottle filled at? I have gotten bad fills before. I will only get a bottle filled at a place where I can watch them zero the scales out and watch them fill it.
To NX problems
