AFRs bench flowed
Old May 26, 2005 | 04:25 PM
flynbludream's Avatar
flynbludream
Who did your original 6.0 heads? It sounds to me like your local bench is reading way low. I don't see how a stage 3 6.0 head which is the same design as an LS6 head can only flow 258@.600. A good stage 3 head should put you at least around 300 cfm at .600.
I would be more interested in the delta of +30cfm on the same bench over a stage 3 head than anything else. A lot of people would kill for that delta on a stage 3.
Old May 26, 2005 | 10:38 PM
Yano's Avatar
Yano
RMCR did my original heads.
The heads were both flowed on the same machine. not sure about other flow machines or if this one flowed low or my altitude had any impact, but to compare my old 6.0L vs the AFR out of the box on this machine at my location. And to see what you guys thought of the numbers/.
Old May 27, 2005 | 01:36 AM
M_T_0's Avatar
M_T_0
1 flow bench/shop does not mean anything relative to the absolute flow #'s the important thing is the delta between the stage 3 6.0L heads and the AFR's on the same equipment at the same time (if we asume that the 6.0L heads are good) and it would be interesting to see the port volume on the 6.0L.
The way I look at it the cost of the AFR's is less than the cost of a stage 3 ported head + core cost and flows > 10% more as well as having a thicker deck and possably lower port volumes, Whats not to like?
After seeing this indipendent post/test I'm even more impressed by the AFR's
More Than Zero
Old May 27, 2005 | 03:23 AM
kumar75150's Avatar
kumar75150
port velocity is a bunch of bull****
gimme a head that flows 340 at 240cc instead of one that flows 305 at 205cc and we will see who goes faster
Old May 27, 2005 | 08:33 AM
mdhmi's Avatar
mdhmi
Kumar - so what head are you recommending over the AFR ?
Mark
Old May 27, 2005 | 11:53 AM
FreddyG's Avatar
FreddyG
to some extent. If you're not racing, and have a smaller cam, and doing mainly street driving (not taking advantage of the Higher flow/RPM potential of the bigger head), then I'd give points to the smaller head. It's more about throttle response than top end,thrown in jail, ticket getting power
The story changes once you go to the track (and use a bigger cam).
I'm not trying to argue, just giving my opinion.
Old May 27, 2005 | 12:09 PM
Phil97SVT's Avatar
Phil97SVT
I'm not impressed either 505/436 out of a 346 which orginally had another major corvette vendor heads.
AFR 205s with a fairly large cam and moderate compression
Old May 27, 2005 | 12:11 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Kumar, I agree. The track results speak for themselves 7,8,9,10's. All the O2 in the chamber is also not used, "instantaniously," but over time.
In fact, an analogy to your point. I would rather take a, almost as fast, two pound crp(like I did this morning) instead of a faster, one and a half pound crp. As you you get older, the sad part is you really begin to enjoy your morning crp, particularly if it is really good. It is the only place I get peace and quite the whole day. lol.
to go do, you know what.
Old May 27, 2005 | 01:22 PM
M_T_0's Avatar
M_T_0
that setup at the track is king as a DD it sucks and It would take a very un-street-frendly cam to take advantage of the heads. but in this case we are talking about a head that flows better AND has a smaller port at the same time it is cheaper to put on your car, so again whats not to like?
In short I do not see the down side to the AFR's
1. at $2400 or so with no core charge where a stage 3 head cost that + a core charge.
2. everyone is dissing them because they only flow 30 cfm better than other stage 3 heads (on the same test stand on the same day)
3. there is more deck thickness which only helps the head stay sealed in boosted apps.
4. as far as I know these are doing all of this and keeping the port volume smaller.
I think that the real ? behind this is why do ported heads cost so much?
I could see us having this conversation if stage 3 heads were costing $1200 - $1800 total out the door, but that is not the case.
JMO
More Than Zero
Old May 27, 2005 | 04:41 PM
caseyse's Avatar
caseyse
5. And the AFR's double quench area :-)
Old May 27, 2005 | 06:15 PM
FreddyG's Avatar
FreddyG
No offense meant or disrespect......................BUT THAT IS WAAAAY TOO MUCH INFORMATION FOR ME, but I do see your point!!!!!!!
Old May 27, 2005 | 11:04 PM
Yano's Avatar
Yano
Old May 28, 2005 | 09:02 AM
  #33
korvetkeith's Avatar
korvetkeith
Port velocity is much more important in carb applications in order to keep the air-fuel mixture suspended. I think LS1s have already proven that big ports don't hamper them much if at all.
Old May 28, 2005 | 11:27 AM
  #34
Skunkworks's Avatar
Skunkworks
First good laugh of the day…, but yah way too much info.
Old May 28, 2005 | 01:51 PM
  #35
M_T_0's Avatar
M_T_0
this is still beside the point.
the point is that they cost less, flow more, produce more power and have more room to be ported to 250cc's (if that is what you want) to flow even more that the other stage 3 heads out there.
the statment that port vel. is not important in the LT/LS1 is missleading, It is less Important in the port Injected engines than it was in the carb engines but it still makes a diff. it also has an effect on detonation due to the turblent flame front. But then its not like us FI guys have any problems with detonation now is it?
I do not own AFR's (yet) but I keep seeing people diss them and there reasons just dont make sense to me. To me If I had a good set of ported heads I would keep them, but if I am buying new there is not a ? about which I should buy.
More Than Zero
Old May 29, 2005 | 12:08 PM
  #36
95wht6spd's Avatar
95wht6spd
Did your tuner use a flow pipe to test the heads? AFR probably did, and it will increase the #s,
Old May 29, 2005 | 02:00 PM
  #37
korvetkeith
Sorry, if the discussion is whether or not AFRs are a good head then I'd say yes.
The turbulence (I'll assume you meant to say turbulent) in the cylinder due to the head will be affected by the valve size and the volume of air a head flows. If two heads have the same size intake valve and flow the same cfm of air, then the velocity of the air going into the cylinder will be the same regardless of the intake velocity upstream of the intake valve.
Futhermore, turbulence in the combustion chamber is more affected by the chamber and piston design and their quench height. And those things come into affect right when it counts, just before the mixture ignites.
To AFRs bench flowed
Old May 29, 2005 | 02:08 PM
  #38
M_T_0's Avatar
M_T_0
yes you are right I was jumping around the better CC is responsable for improving the deton. propertys of the AFR's
my point was that on this post the AFR's were getting dissed because they ONLY flow 30 cfm better than a set of stage 3 heads.
More Than Zero
Old May 30, 2005 | 04:21 PM
  #39
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Regardless of airflow numbers, I can always tune an AFR head leaner and with more timing. This alone makes the head worth the price.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old May 30, 2005 | 07:42 PM
  #40
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I'm intrigued... can you quantify how much more timing or how much leaner you've run the AFRs vs. the WCCH stage II heads?
