AFRs bench flowed
Old May 26, 2005 | 12:45 AM
Yano's Avatar
Yano
Default AFRs bench flowed
I dont have the sheets or any of the other data. Will see if I can get the printouts. I know that you can really hog out heads and get big numbers, and AFR has great port velocity as well as high flow numbers. No idea what the velocity is on 6.0L heads.
But my tuner called me today with the numbers. They ran the test on the same machine, same setups etc etc
My old setup was 6.0L heads stage III 2.02 valves and 1.60
258 at .600 intake and 217 at .600 exhaust
AFR 225's right out of the box 2.080 and 1.60 valves
288 at .600 intake and 214 at .600 exhaust.
on the website AFR shows
320 at .600 intake and 250 at .600 exhaust
That is a solid 40cfm higher on both.
Any ideas why the local tuners numbers were so low, or why AFR numbers are so high????????????????????
Old May 26, 2005 | 01:07 AM
TURBO VET's Avatar
TURBO VET
That is very interesting. I would like to know the same thing. I was thinking of getting a set of AFR's or Allpro heads. I was leaning towards the AFR's due to the flow numbers but now I don't know.
Old May 26, 2005 | 03:23 AM
kumar75150's Avatar
kumar75150
flow benches vary a little but i didnt think they varied that much
dont let Tony Mamo see the numbers; he will call your tuner a liar that doestn know what he is doing
Old May 26, 2005 | 05:49 AM
mdhmi's Avatar
mdhmi
Maybe because your local tuner doesn't care about selling you heads.
Mark
Old May 26, 2005 | 07:17 AM
SS930's Avatar
SS930
Mark
Might be some truth to that!
Old May 26, 2005 | 07:33 AM
7LitreC5's Avatar
7LitreC5
Can air density affect flow numbers? It seems like it could but that is out of my area of expertise... The flow testing was done on a SuperFlow flow bench at an altitude of ~6000 feet.
I asked the local guy what bore size was used to obtain the flow numbers and he did not know. He was going to check.
Old May 26, 2005 | 10:17 AM
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
Default AFR vs Stock
Every flow bench operator is different. It all depends on temp,inches of vac.,velocity stack used on ports,and cyl. bore size. But @ least you can see that there was a 30 cfm difference between the two heads with the same conditions.
Old May 26, 2005 | 11:03 AM
Jesse_Boyer's Avatar
Jesse_Boyer
do you have low lift flow numbers too? I'd like to see them for both sets
Old May 26, 2005 | 11:23 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Out of the box the AFRs do really good.
Just for reference my LS6 Heads done by A&A's head shop flowed
298 @ .500 lift and 312 @ .550 lift on the intake. Exhaust was 255@.550 lift. Chamber Volume 77cc. 2.02 and 1.577 Valves.
Old May 26, 2005 | 12:00 PM
Yano's Avatar
Yano
Ok here are more numbers
AFR heads
@.100
67 in 58 ex
@.200
155 in 110 ex
@.300
216 in 160 ex
@.400
252 in 193 ex
@.500
280 in 203 ex
@.600
288 in 214 ex
@.700
294 in 221 ex
Old May 26, 2005 | 12:10 PM
Jesse_Boyer
Nice numbers, but same question as above. What were the low lift numbers? Also, do you know the intake runner volume?
Old May 26, 2005 | 12:24 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Default My LQ9's flow 348cfm at .600
Mine are about 20 cfm short of absolute best (non-C5R LS6) heads right now from TEA or Cartek IV's. Still waiting to be impressed by the AFR's. So is Cartek. Maybe someday, we can strap those things on to bench and go down the 1/4.
Old May 26, 2005 | 12:56 PM
Pickleman's Avatar
Pickleman
Default Numbers Schnumbers!
Sooooooo When are going to get that Bad Boy Back on the Streets?
Pickleman
Old May 26, 2005 | 12:59 PM
Shinobi'sZ's Avatar
Shinobi'sZ
I will have to find my sheet, I bet I got them beat.
You noticed I was hitting over 300 without going up to .600 lift too.
Old May 26, 2005 | 01:27 PM
Jesse_Boyer
Exactly. That's what caught my eye. I'm not planning on a big-lift cam...
Old May 26, 2005 | 03:08 PM
#001 2001 Z06
299 cfm at .450 for me. Just E-mailed flow sheets to Kevin. I am retarded in the posting department.
Old May 26, 2005 | 03:35 PM
Shinobi'sZ's Avatar
Shinobi'sZ
I just read your flow sheets. I think I know who did those heads, he did great work (Tim). Richard owns WCCHs..he is not only cool but is a Master. Great numbers with the 6.0l heads. It looks like the LS7 heads are going to flow like 360 from the factory, but I can't remember what lift. It will be interesting when the LS7 heads start hitting the streets, so we can get some additional flow data on them.
To AFRs bench flowed
Old May 26, 2005 | 03:44 PM
FreddyG's Avatar
FreddyG
What size are the intake ports on the new LS7 heads, that definitely will help high lift flows, and, I believe that they have 2.1" intakes, which also helps flow. Nonetheless, they will be one of the nicest set of heads available for a stroker, much less an OEM head!
Old May 26, 2005 | 04:09 PM
Jesse_Boyer
Although, they might not be ideal for low cube engines if the intake ports are large, right? Big port, low velocity = lower torque at low R's
Old May 26, 2005 | 04:17 PM
FreddyG's Avatar
FreddyG
That's how I see it, but there are guys on this forum that forgot more than I know! I'd think that the heads were made to flow some big numbers, and would work with a big cam (.600"+ of lift). We'll see how they work in a couple of months.
