Completed Ptk Project Pics
Old Jul 8, 2005 | 02:48 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Originally Posted by babala65
Thanks, I made the coil relocation stuff from 1 1/4"strips of aluminum sheet metal (for the mounting bracket), brake line(for the spacers), washers, and threaded rod. It did not require me to do any splicing to the stock wire harness I just had to make up new plug wires.
Got any better pics of the bracket or where you relocated yours to? I want to relocate mine soon, I just don't want to pay through the nose to do it. Also, what'd you make the plug wires out of? Did you use the ends from your existing plug wires and just add an extra length of wire between the ends?
Old Jul 8, 2005 | 03:26 PM
mdhmi's Avatar
mdhmi
Looks very nice. Who is doing the tune?
We're going to have a ball at the next Milan track rental..
Mark
Old Jul 8, 2005 | 03:35 PM
VETZILLA's Avatar
VETZILLA
Mark
1st Annual TTi / PTK Shootout ????????????????????
Old Jul 8, 2005 | 04:03 PM
mdhmi's Avatar
mdhmi
I think the field will be big enough to have classes of C5 FI at our Milan rental. Stock cubes vs Big Cubes, Stock Botton-End (caugh caugh) vs Forged Motor, etc, etc. I get a half second head start though as you have an auto.
Mark
Old Jul 8, 2005 | 04:20 PM
supercoupe01's Avatar
supercoupe01
Cool looking set-up.
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
Excellent job!!
Old Jul 8, 2005 | 06:39 PM
babala65's Avatar
babala65
I will take some better pics of the coil brackets, I did use the stock coil ends and new spark plug boots and terminal ends.
Old Jul 8, 2005 | 06:43 PM
babala65's Avatar
babala65
Mark
Phil is going to be doing the tune, when is the next track rental?
Old Jul 8, 2005 | 07:24 PM
hpcubed's Avatar
hpcubed
Absolutely beautiful. :o
Old Jul 8, 2005 | 07:28 PM
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
Glad you finally got the system in the car, hope you enjoy it. Let me know if you need anything else.
Jose
Old Jul 8, 2005 | 08:06 PM
dads01dream's Avatar
dads01dream
I'm speechless Is the motor stock cid? Any cam/head work done? That engine compartment looks so good you oughta get a plexiglass hood!!!
Old Jul 8, 2005 | 09:28 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
WOW.......that looks GREAT Good luck and with Dr. Phil you will be in good hands for sure
Old Jul 8, 2005 | 09:36 PM
  #33
Indiana Z06's Avatar
Indiana Z06
Incredible!
Old Jul 9, 2005 | 01:55 AM
  #34
babala65's Avatar
babala65
I did a few little things
Old Jul 9, 2005 | 02:45 AM
  #35
ONealLaw's Avatar
ONealLaw
St. Jude Donor '05-'06
Very Nice setup.. Man that sure is pretty.
Old Jul 12, 2005 | 11:41 PM
  #36
babala65's Avatar
babala65
Thanks Oneal
Old Jul 12, 2005 | 11:46 PM
  #37
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Default Some of talent here
never ceases to amaze me. Very nice.
To Completed Ptk Project Pics
Old Jul 12, 2005 | 11:52 PM
  #38
chriswtx's Avatar
chriswtx
WOW!! So how do you change those spark plugs...
Old Jul 13, 2005 | 12:58 AM
  #39
Shinobi'sZ's Avatar
Shinobi'sZ
I just changed out my spark plugs to switch to a colder plug. If I had to do it again it would take about 1 hour to do. That is not counting jacking the car up.
The passenger side plugs can all me reached from the top.
The drivers side #5 & 7 need to be removed from underneath the vehicle...actually very simple. I just put my arm between the oil filter and frame with a socket and took them off. My arms are not as big as they used to be, but even at 18" they fit fine.
#1 & 3 have to be removed from the top and can be done using 2 extensions, 1 universal, and a swivel spark plug socket. It was easy with the extensions I slid them right under the waste gate vent tube and removed and installed them.
Hopefully this will end the "how do you change the spark plug" questions that seem to be the big question when somebody sees this kit...it starting to become a little humorous.
Old Jul 13, 2005 | 02:33 AM
  #40
Yano's Avatar
Yano
This kit looks so awesome on your car.
I think if I had seen these pictures of the PTK kit, I would have done this kit over the TTiX kit.
For some reason it just doesnt look like the huge spider web kits of the early shots.
This looks AWESOME FOR SURE!!!!
