Nitrous Window Switch Help
Old Jul 19, 2005 | 01:25 PM
FLC6's Avatar
FLC6
Default Nitrous Window Switch Help
On an 05 C6 Auto:
Which wires on the ecu to tap into for the window switch?
Also, is it easy to install the fuel pressure switch?
Old Jul 19, 2005 | 01:48 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Not sure what wires, but contact MSD they should know....
A fuel pressure safety switch just screws into a manifold on your fuel rail. It is set with a screw.
Old Jul 19, 2005 | 01:53 PM
FLC6's Avatar
FLC6
SO will fuel spill out when I unscrew the manifold?
Thanks!
Old Jul 19, 2005 | 10:28 PM
creighton's Avatar
creighton
You have to take the schrader valve out of the fuel rail before the fpss will work. If you let the pressure in the fuel rail bleed down before removing the schrader you shouldn't have much fuel spill out of the rail.
Old Jul 20, 2005 | 06:15 AM
viper punisher's Avatar
viper punisher
pin 10 on the pcm located behind the right wheel well. It's the white wire. Take the plastic cover off the pcm plug and you can read the pin numbers.
Old Jul 20, 2005 | 11:27 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
I would ask in the c6 boards cause the tach wire is on a diffrent pin then in the c5 i belive its a blue wire in the c6 but i dont really know. Yes when installing the fpss fuel will spill out, have something ready to clean it up with and before installing it you should put some teflon paste on all of the treads cause it will leak if you do not.
Old Jul 20, 2005 | 05:18 PM
FLC6's Avatar
FLC6
Thanks guys.
Yes this is for a C6 not a C5. I tried in the C6 section with no luck. Wish we had a N20 Section.
To Nitrous Window Switch Help
