Torque converters...
Old Jul 26, 2005 | 07:13 AM
BLOWN'NC's Avatar
BLOWN'NC
Default Torque converters...
Who makes the best units? Vigilante. B&M, TCI? Is one better than the other if the power rating is the same? There's a good bit of diff in $, just wondered if there was the same diff in performance/durablility.
Old Jul 26, 2005 | 07:26 AM
ONealLaw's Avatar
ONealLaw
St. Jude Donor '05-'06
I have a Yank converter and I love the way it performs. It pulls dual duty perfect on the street/strip. Here is their website:http://www.converter.cc/
Old Jul 26, 2005 | 08:04 AM
C5 CU's Avatar
C5 CU
probably most popular are Yank and Vig....
Old Jul 26, 2005 | 09:36 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
i have tci's new billett 5 clutch lockup. do a search on customer service, here and ls1tech and youll see how they rank.
kevin winstead is the head stall engineer over at tci
Old Jul 26, 2005 | 09:51 AM
BLOWN'NC's Avatar
BLOWN'NC
Looking at the vigilante 2800.
Old Jul 27, 2005 | 01:55 PM
LS1LT1's Avatar
LS1LT1
Great converter but I'd go bigger.
Old Jul 27, 2005 | 03:30 PM
BLOWN'NC's Avatar
BLOWN'NC
My car is an A4 with 3.73s, ATI, H/C, LT headers/exhaust, etc. Much more and traction will be even a bigger issue right?
Old Jul 27, 2005 | 03:56 PM
c5mtl's Avatar
c5mtl
go bigger at least 3500
Old Jul 28, 2005 | 07:34 AM
BLOWN'NC's Avatar
BLOWN'NC
I rarely track the car at the strip. Just want a little higher stall for faster acceleration. Why is everyone saying go higher?
Old Jul 28, 2005 | 08:06 AM
C5 CU's Avatar
C5 CU
I am told the Vig 2800 stall is close to Yank 3200 .... Vig 3200 is similar to Yank 3500 or 3600.
Old Jul 28, 2005 | 08:36 AM
flatlne's Avatar
flatlne
I am running a Yank 3500 I had a Vig 2800 just the conv swap gave me almost a half sec 1/4 the 3500 is great no real diff. in normal driving (stock motor with 7# ATI)
Old Jul 28, 2005 | 08:39 AM
flatlne's Avatar
flatlne
Do The 3500 you won't be sorry.The first time you stand on it you will agree.The car will still be tame when it needs too.Trust me I had both.
Old Jul 28, 2005 | 11:29 AM
BLOWN'NC's Avatar
BLOWN'NC
I'm into the 11s with absolutely no stall. From the brake to the gas at the green light with a 2.8 60' time. Traction is my biggest issue. I don't see a higher stall doing anything to help that. My tuner and friends that drag race tell me no higher than a 2800. Remember this is an A4 with 3.73 gears too!
Old Jul 28, 2005 | 11:38 AM
flatlne's Avatar
flatlne
I did not want to swich from my 2800 till I had a car from Cartek post a 10.98 to my 11.8 with a sim. setup.Both are nice conv. try a set of bfg drags check the parts section I got a best of 1.70 60'
Old Jul 28, 2005 | 07:51 PM
blu00rdstr's Avatar
blu00rdstr
FLP recommended the Vigilante converter for my Level 5 trans. The reason was the forged components. Apparently FLP had rebuilt a few transmissions where they found converter bits inside as a cause of failure.
I agree that if you compare converters, estimate the Vigilante stall speed 400rpm higher than advertised. I had a 3000stall, under slight accelleration (inching forward in traffic) the car would rev at 2500rpm. I had it restalled to 2600, and it drives much more like stock, it now brake stalls* at 2,000rpm (hold brake and raise rpms till the tires start scratching).
*Some converter companies say brake stall testing may damage your converter, others say it measures the clamping power of your (rear) brakes, and others say brake stall is 400-800 rpm lower than true stall.
To Torque converters...
