show me your fi fuel system
Supporting Vendor
1 Post
I am doing a little work to mine (excuse the messy hose/wiring going everywhere). Here are the basics:
FAST fuel rails
Aeromotive fuel pressure regulator
Twin Walbro fuel pumps mounted in fender well
Hidden surge tank near main fuel tanks
Racetronix in-tank pump
As you can see, the regulator is mounted on the passenger rail. The driver rail crosses over to the regulator. I feed fuel, one pump per rail, on the part of the rail concealed near the firewall. The 6AN hose just hops over near the brake booster and down into the fender well.
I had a different surge tank hidden elsewhere but it was seeing pressure and it burst the aircraft style lid seal. So I went with a different tank that's a little smaller but can see high pressure with no problems (custom fabbed out of aluminum).
I am actually worried the Walbro pumps will push too much fuel and overcome the regulator!
Again, excuse the mess in the engine bay and near the pumps, I am still cleaning everything up.
FAST fuel rails
FAST fuel rails
FAST fuel rails
Hmmmmm, someone is getting ready to do some very naughty things with their car
Looks good hope you will be able to hear the engine over the fuel pump whine, so when are we going to see how much boost can be squeezed out of the TTi X. Might as well get the blueprints for backhalfing the car from SR71 I see you have been completely turned to the dark side like him.
Where are you putting your inline filter, mine fits nicely up above the drivers side tank in the tunnel.
Mike
I have 2 of the very same fuel pumps hanging under my drag cell. I didn't spend the coin for new rails though. I'm a cheap bastich. took the 2 #6's from the pumps into a #8 to the frount. I then hollowed out the pulse damper and welded a #8 fitting to it and hooked the feed to it. I cut the factory flex line and installed a regualtor there. the factory feed line is now the return. no fuel problems yet.
Just another example of R. N. E. in its finest form.
Supporting Vendor
1 Post
Again, I've had this type of fuel system running before, it ran great for 2-3 hours with zero pressure issues... and then the surge tank itself blew a seal. And although I had zero fuel pressure issues I had a smell and safety issue to contend with.
Mike
Mike
Did you put anything in there that creates 45-50psi in front of the intank? If you haven't yet? I would suggest keeping a gallon of gas with you.
I have a fairly identical setup except for the rail type and I don't have the surge in place yet. However, when my gauge showed an 1/8th of a tank the car all of a sudden lost pressure and died. I thought the intank pump may have died and sat 4 hours waiting for a flatbed. When I got her home I checked things out and they were fine. Dumped a gallon into her and she fired right up. Ran around w/ a gallon w/ me and tested it and it did the same thing.
After I put a regulator in between the pumps I hadn't had the problem.
If it isn't happening then great.. but until you've actually run it for awhile and know you're actually going through a complete tank, keep it with you.
Supporting Vendor
1 Post
Supporting Vendor
1 Post
Originally Posted by Z06GMAN
There are better Pictures at the FLP web site. I should be good to about 2000 rwhp
Has anyone tried running twin in-tank Racetronix pumps (or 255's) into a "Y", using a -8 line to the front, with an aftermarket fuel reg like DIYNOOB has, and use the factory line as a return?
I'm going to be upgrading in the future and was thinking this might be a cheap and effective system... w/o all the noise.
Location: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I've got an in-line Bosch pump with Aeromotive filter feeding a '97 line set / front mounted rail/regulator system all comming from a rear mounted custom surge tank and return regulator. Both the in-line pump and front regulator are boost referenced but not the LPE in-tank.
This system has successfully supported full boost with no gauge perssure drop in all the conditions that we (JB and myself) could think of...Stop and go traffic, boosted pulls with less than 1/8 tank of hot gas, high "G" corners under boost, 6000 ft elevation climbs while continuously boosting, being able to run the gauge into the red, etc. After going through a few other recommended set-ups that I was told held on everybody else's car but would fail on mine I can confidently say that this combination works as it should.
Supporting Vendor
1 Post
I know a few people have put larger pumps inside the tank successfully, but it was purportedly a tight fit for whatever reason, and the fuel level sender didn't function as it was supposed to.
Also, by simply upgrading the in-tank pumps, you still have a separate fuel starvation issue that can start to occur around 1/4 tank. The bucket for the factory fuel pump is supposed to help solve fuel starvation under acceleration/high Gs, and it does for mild/stock setups... but when you start talking about 500rwhp+ FI setups, it's just dangerous to run your car below 1/4 tank as that's the point (at least on mine) where your A/F starts to go lean.
Again, FWIW, the twin Walbros I have do not make that much noise. Unless you're running stock heads/cam and stock exhaust you won't notice the pumps.
If only our factory fuel tanks were sumped and baffled, this whole thing would just be a matter of dropping an 8AN bulkhead fitting into the sump and putting a monster fuel pump outside of the tank.
Some pumps do make some noise.. One of my inlines was loud and pretty noticeable.. the other was very quiet. Make sure the vendor you get it from is able to take it back for an exchange if that becomes the case..
I got it exchanged and they're now barely noticeable..
FWIW, I'm getting by with 60 # injectors, a Wahlboro (Racetronix) fuel pump, and spraying a little meth. The meth is totally optional with my setup, however.
Mark
Mark
I think the problem with running larger/more pumps in the tank was available space and the fuel level sender. It's been a few years since I went in my fuel tank so I don't recall specifically, but that's what I've been told.
TTT... please post more ideas if you have them!
Gary, who is FLP? Do you have any more details on your system? Are those bulkhead fittings installed in your factory tanks? If so are there any issues with doing so? Any in tank baffles? How is the system laid out and what components were used?
DIY, where did you get your surge tank? Do you have any pics of it and how (where) it's mounted? So you have the intank pump feeding the surge tank which is located in the back and the twin external pumps mounted in the front behind your FL tire? Usually the external pumps are mounted near the tank because while they do a great job of pushing fuel, they are poor at pulling in fuel.
1 Post
TTT... who is FLP?...
Mike
St. Jude Donor '06
