simple question---no answer
Old Aug 27, 2005 | 01:02 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default simple question---no answer
hitting the rev limiter will cut injector and cause lean condition.
question one is ... does the spark get cut too to that injector?
question two is.... if it doenst, is that a bad lean condition or is it no big as no fuel no combustion therefor no problem.
thank you
Old Aug 27, 2005 | 01:11 AM
QuickSilver2002's Avatar
QuickSilver2002
thank you
I've always thought it cut fuel and spark, but I have recently been seeing some info from people looking at the actual PCM code that says it just cuts fuel.
Right, no fuel no combustion, but what happens if you are spraying fuel with another source besides the injectors (n20 fuel noid/alky).
I have bounced on the rev limiter many times and it sure seems like it cuts spark to me. I've never had a problem and I have been on the rev limiter more than I want to admit.
It is impossible to see what the AF ratio is under those conditions since some of the cylinders get no fuel. You would have to have a sensor on each cylinder.
Old Aug 27, 2005 | 08:52 AM
NICK YOSKIN
St. Jude Donor '08
thanks quick..
lets keep it coming guys/gals!
Old Aug 27, 2005 | 11:01 AM
Julio's Avatar
Julio
With Alky or NOS hitting the rev limiter is not a good thing. The limiter should be set where you wont hit it unless a severe overshoot.
With mild systems, there's been no reports of issues hitting limiters. With aggressive systems.. then there have been issues. Aggressive as in twin nozzles at 200 PSI pressure on 4 cyl motors.
Reasons are pre-ignition issues. My understanding is the PCM pulls fuel typically.. but shutting down a motor under a lot of boost at high RPM's=trouble... remember when a cylinder doesnt fire, the crank yanks the piston down. And if you look at the bottoms of pistons..there's not a lot of material there under the pin area.
Bottom line.. careful when you race the motor..
Old Aug 27, 2005 | 11:29 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Very good explanation!! Thanks!!
VR
Old Aug 27, 2005 | 12:30 PM
QuickSilver2002
How would this be any different than the intake stroke. It should be about same stress, right? Seem like it would acually be less stress than the intake stroke on a NA setup.
It is really hard to stay off the limiter on a high hp street setup. The tires let go and you are on it before you can react.
Old Aug 27, 2005 | 12:40 PM
Shinobi'sZ's Avatar
Shinobi'sZ
thank you
I am very careful about bouncing off the Rev Limiter. For one it actually slows you down if you are trying to go fast. The first thing I do with a new setup is familiarize myself with how performs on the vehicle. Not because I don't know where the rev limiter is set at, but because when the tires break loost the tach swings so fast, I shift before it hits the limiter.
It is my understanding that the rev limiter retards the timing and cuts the fuel.
Old Aug 27, 2005 | 01:44 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Old Aug 27, 2005 | 03:39 PM
QuickSilver2002
Originally Posted by AMERICAN_HP
Yea, it has always been my understanding that it cuts fuel and spark completely on alternating cylinders, but I have recently seen some reliable info that states otherwise.
The guys at efi-live have been modifying the os code to enable a 2 step... they mentioned that the rev limiter routines do not mess with spark, but it is still possible that there is a something deep inside the code that they missed. There could also be something that is not software (could be hardware) that causes spark to cut without a fuel pulse.
Old Aug 27, 2005 | 05:40 PM
Hool97's Avatar
Hool97
It pulls fuel only. Then if other conditions are met then timing and traction control, like wheel spin beyond normal conditions ( in ls1 edit this is detectedd in the delta change for acceleration xmph/sec). I changed mine to allow for 30mph per sec. not exactly real world right. I think the stock is 10mph/sec limit. Again if timing is retarded its likely a subsystem.
Old Aug 27, 2005 | 06:22 PM
kman0066's Avatar
kman0066
That's what a Window Switch is for with NOS as I understand it. It activates the NOS at a certain RPM and deactivates a certain RPM. You can set it for right before your limiter so if you do hit the limiter, the NOS has stopped and won't overrev or explode the crap out of your motor.
Old Sep 5, 2005 | 12:47 AM
NICK YOSKIN
St. Jude Donor '08
so the finally answer is?
Old Sep 5, 2005 | 12:36 PM
Chris Stewart's Avatar
Chris Stewart
Hitting the Rev Limiter with N20 has happened to me many times while spraying and it never caused a problem. It's usually just kissing the limiter and not a long event. Anyone else that races with N20 has surely done it too. I don't use a window switch. So we can rule out instant death for that scenario.
To simple question---no answer
