Big Trouble....
Old Sep 1, 2005 | 12:28 AM
Z06VET's Avatar
Z06VET
Default Big Trouble....
Finally got the car back today and tonight something went ... badly.
Took the car for a romp since it's been in the shop for 2 weeks with the tranny replacement . Pushed it to about 5200 rpms in 5th and 6000 for all other gears prior . Noticed a loss of power at 5200 and got out of it . Slowed to a stop a bit later for a right turn off merge and the car is encased in smoke !
Limped it home smoking and found oil all over the passenger side of the motor and underneath the car. Doesn't look good .
Damn , Damn , Damn... Feel like
Dan
Old Sep 1, 2005 | 12:34 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Sorry to hear about that... is it leaking coolant too??
VR
Old Sep 1, 2005 | 12:41 AM
Z06VET's Avatar
Z06VET
VR
No coolant , oil only.
Dan
Old Sep 1, 2005 | 12:45 AM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Check your oil line to the turbo and make sure that it's tight to the turbo and oil pan.
Then look at the body of the turbo and see if it's wet, if so you blew a seal in the passenger side turbo.
I hope after some hard runs you let the car idle to let the turbos cool down before you turn it off.
Old Sep 1, 2005 | 01:06 AM
Z06VET's Avatar
Z06VET
Starting to feel alittle better if this might be the case . I was having thoughts of something more catastrophic . There is hope it could be something else . Thanks.
Dan
Old Sep 1, 2005 | 09:04 AM
speedz06's Avatar
speedz06
Blow out the dipstick?
Old Sep 1, 2005 | 10:12 AM
Z06VET's Avatar
Z06VET
No . Dipstick still in place .
Dan
Old Sep 1, 2005 | 01:23 PM
Z06VET's Avatar
Z06VET
Oil looks like it is coming out the breather only , all other connections appear to be ok .Oil bypass and out the breather when under some load . Ring or a piston probably . Spark plug black with oil .
For those of you keeping score ,chaulk mine up in the "blown" column . This sucks. . Guess I'll start looking into the forged motor alittle harder now.
Dan
Old Sep 1, 2005 | 02:22 PM
blu00rdstr's Avatar
blu00rdstr
Sorry about your luck. I joined the blown column two days ago, but with a forged motor.
Old Sep 1, 2005 | 02:31 PM
tlaselva's Avatar
tlaselva
When you’re running boost, you know your castrating the longevity of the engine. Some go for years, some last minutes. But eventually, the piper will have to be paid.
How much boost were you running?
Now go build a forged, boost friendly motor.
When live gives you a lemon, make lemon aide!
Old Sep 1, 2005 | 03:26 PM
DDSLT5's Avatar
DDSLT5
DOH!!!
More details brother! Were you running a procharger?
Old Sep 1, 2005 | 03:33 PM
Z06VET's Avatar
Z06VET
Always knew a forged motor would be in the cards , I hoped it would be later than sooner .
Running @ 9 - 10 psi .
Dan
Old Sep 1, 2005 | 05:04 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Dan
9-10psi is quite a bit on stock Z06 compression. When you forge your motor, consider lowering the compression or lowering the boost. It's not that you can't get away with what you're running now, but I think that relies on having a perfect tune.
Old Sep 1, 2005 | 06:06 PM
mdhmi's Avatar
mdhmi
Wrong answer. Wrong answer.
Mark
Old Sep 1, 2005 | 07:04 PM
Hool97's Avatar
Hool97
That really blows, sorry to hear it. I figured i'm in the same boat therefore i'm going forged before i find myself stuck on the side of the road.
Old Sep 1, 2005 | 07:53 PM
b98's Avatar
b98
call A&A.
Old Sep 1, 2005 | 07:55 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Sorry about the misfortune,but I have to ask. Hows the transmission?
To Big Trouble....
Old Sep 1, 2005 | 08:12 PM
Dragonsi's Avatar
Dragonsi
hopefully its just a turbo, does it idle normally? when u felt loss of power, did it like feel like where did my boost go? or wtf y does my car feel like a 4 cylinder, i'd check your compression just to look into the worst
o ok nvm, so it is a piston rng probably, that blows... no pun intended
Old Sep 1, 2005 | 09:10 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
SORRY to hear about your potential misfortune. My z06 with its new ECS D1SC KIT also makes 10 lbs of boost at 6500 rpms or so and in an attempt to make my motor live longer i put my rev limiter to 6500 and will shift between 5500 to 6000 where i should only be seing around 7 to 8 lbs of boost. I realize though that it may just be a matter of time that i call ECS and tell them to start building me that forged short block but hopefully that will be later than sooner.
HOw many miles did you have logged on with your turbo motor and BLUEROADSTER how much boost were you running when your engine went KABOOM!!!!!!! (sorry to hear about your misfortune also that SUCKS and on a forged motor to)!!!
Old Sep 1, 2005 | 09:24 PM
1%r's Avatar
1%r
Dan
If you did your motor in you probably had boost spike.
I know the you have an HP tune on the car, were you logging where you can look @ the histogram?
If your not logging go out and buy a laptop and HP if it's not yours and log.
Reconsider doing your fuel system with the ECS one.
Do a leak down and check all the connections on the catch can and can itself.
BTW what vac. are you showing @ idle on your boost gauge?
