Fuel System Setups
Old Sep 1, 2005 | 09:34 AM
kromberg's Avatar
kromberg
Default Fuel System Setups
Please give me your fuel system setups including pump type, boost-a-pump type, fuel line types, regulator location, and finially horsepower?
Thanks,
Keith
Old Sep 1, 2005 | 09:57 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default mikes99corvette
Early C5 Fuel System + KB Boost A Pump + Racetronix Fuel Pump
625RWHP Never had a problem needing fuel!
Old Sep 1, 2005 | 10:18 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
For those with serious HP issues we have designed a fuel sytem that can hold, within reason, as much hp as an LSx engine can make without the fuel press gauge even budging.
It is very quiet for street use, and the tanks drain properly. They can also be ran almost emty without running dry.
Give a call if your interested.
This includes late 03/04's BTW
Old Sep 1, 2005 | 10:21 AM
mdhmi's Avatar
mdhmi
I have a 2000 Vette that makes 550+ rwhp.
Racetronix pump with hot wire kit. 60 # Motoron injectors. ECS Meth kit.
Mark
Old Sep 1, 2005 | 05:42 PM
Tomulrich's Avatar
Tomulrich
ECS.....can you tell me more about the fuel system. Does it utilize intank or inline or a combination? What fuel lines, tank ,sump???please give me more info I am very interested.
Also what level of FI horsepower do you think it can support?
What is the price and what does it include?
Old Sep 1, 2005 | 06:50 PM
DOUG @ ECS's Avatar
DOUG @ ECS
It includes all fittings, s.s.hose, an ecs adaptor to supply the pump, filter, polished fuel rails, regulator etc. In other words every piece necessary to have your fuel system completed.
We retain the stock pump in the tank while having a secondary pump but really not in line as it has it's own feed supply.
So far we have used in several cars making 700rwhp to over 1000rwhp without so much as a budge in fuel pressure. Plus most importantly it's quiet so no problem on the street with annoying noisy pumps. This pump does cost a premium but after all it is for a Vette!
The complete kit is $1995 for all model C5's, but they are year specific.
Check our post on the Paxton superchargers, the picture in it is of my car with the rails and regulator showing.
and thanks for the alky kit order!!
Old Sep 1, 2005 | 07:37 PM
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
I have a set up with a little bit of HP and it works perfectly!
Old Sep 1, 2005 | 08:15 PM
kromberg's Avatar
kromberg
Doug,
How much horsepower the following setup could support:
- Racetronix intank pump
- Kenny Bell Boost-A-Pump
- -8an feed lines
- -6an return
- Billet Fuel Rails
- -8an Crossover
- 75# RC Engineering injectors
- CAGS regulator at the rails
A person from Racetronix said it will only support 600 FI rwhp, but the person I bought the system from said it will support 800 rwhp. Who to believe
If I need to do something, I would like to do it now when most of everything is still fairly accessable.
Keith
Old Sep 1, 2005 | 08:23 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
I have the 1st system that Doug did that he's refering to.
Very quiet and very reliable.
I did over 800 to the wheels and the car was pig rich. This IMHO is the only way to go if your looking to put down big numbers.
Old Sep 2, 2005 | 12:25 PM
Z06 Tom's Avatar
Z06 Tom
Same, same. HP about the same too. Great minds and all that...
Old Sep 2, 2005 | 12:49 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Racetronix in-tank pump
Twin Walbro GSL392 pumps fed by a surge tank
No KB BAP or anything like it. 600rwhp right now, going to try for 700+ soon.
Old Sep 2, 2005 | 04:38 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Originally Posted by kromberg
Doug,
- -8an feed lines
- -6an return
- Billet Fuel Rails
- -8an Crossover
Keith
I would say a minimum of 650-700RWHP. I have not made your excact system before but from what your listing I would definatly say over 600rwhp. good luck with it!
Old Sep 2, 2005 | 07:32 PM
kromberg's Avatar
kromberg
Thanks Doug
Keith
Old Sep 2, 2005 | 08:23 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Doug,
- -8an feed lines
- -6an return
- Billet Fuel Rails
- -8an Crossover
Keith
From my experience, your weak link is relying on just the Racetronics pump. It can only push so much fuel to the front under pressure. Watch it very carefully especially with less than 1/3 fuel and/or hot gas.
Not the ONLY way to go...
346, D1, 700rwhp, BAP, 60# injectors, LPE in-tank, Bosch in-line, surge, regulator x 2, FACTORY '97 lines and rails, pushing 75psi and rock solid anywhere/anytime even below 1/8th tank hot or pullin' high "G's" on the roadcorse.
Old Sep 2, 2005 | 09:48 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Billet rails have to be cut/rewelded to fit on the driver side. --I just did a fuel system that way for a little F1 car we are doing
Old Sep 2, 2005 | 10:10 PM
SS930's Avatar
SS930
Is this so they don't hit the firewall?
Old Sep 3, 2005 | 08:20 AM
kromberg's Avatar
kromberg
Yep, I had to modify the firewall slightly with my setup.
Keith
Old Sep 3, 2005 | 08:23 AM
kromberg's Avatar
kromberg
Is the LPE intank pump a bucket style like the factory one or the Racetronix one. The person from Racetronix told me not to use an inline pump with a bucket style inline pump. Never gave details why not to........
Keith
Old Sep 3, 2005 | 07:58 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Keith
The Racetronix and LPE fuel pump and bucket are the same.
Racetronix adds some upgraded hardware as outlined in our ad.
To Fuel System Setups
