4L60E and FI
Old Sep 5, 2005 | 06:18 PM
hightest's Avatar
hightest
Default 4L60E and FI
I was wondering if you A4 guys recommend maintaining the stock converter for a FI application. Will the stock TC handle the increased horsepower & torque?
I don't have a "built transmission" so I am a little concerned with using a bigger TC and increasing the torque to the trans too much.
What do you guys with the experience recommend?
Thanks for all of your replies to my FI threads so far.
Old Sep 6, 2005 | 12:08 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
well generally speaking fi guys runs stall from 2800 to 3200.
you can run stall on stock but youll need cooler.
Old Sep 6, 2005 | 12:48 AM
hightest's Avatar
hightest
Thanks for the reply. Do you know if the stock TC will handle the higher HP and Torque? I already have a 24,000 race cooler installed.
Old Sep 6, 2005 | 01:13 AM
NICK YOSKIN
St. Jude Donor '08
i dont know, probably though.
sorry cannot be more difinitive
Old Sep 6, 2005 | 10:14 AM
corvettebob1's Avatar
corvettebob1
I have about 47K on my stock converter with a stock A4 and I added the Procharger at 28K.
Now I also have 3.42 gears that lower the loads on the rest of the drivetrain.
Adding a higher stall converter will result in 2 things 1 is no traction, 2 is early transmission failure.
Old Sep 6, 2005 | 10:28 PM
hightest's Avatar
hightest
Thanks corvettebob1,
How do you like your procharger set-up?
Any issues that you've come across?
Thanks!
Old Sep 7, 2005 | 10:56 AM
corvettebob1
Thanks!
Since I have 1 of the early ones, I had the belt alignment issue and idler bearing issues but I have corrected both.
The 1 thing you will need to do is pin the crank, and if I were you I'd toss the factory balancer and replace it with an ATI Super damper.
Overall I love the kit, it just needed some R&D before it was released!
Right now I have a tuning issue and heating issue, but that appears to be caused by a move from Mich. to Fl. and there a huge shortage of good tuners in NE Fl.
I will be installing a DeWitts HD rad. and lowering it to return to the factory dual fans. The Procharger 2 speed fan worked Ok in Mi. but down here if your doing 70 mph it's Ok!
You can PM me @ corvettebob1@comcast.net for more info if you'd like.
Old Sep 8, 2005 | 12:52 AM
hightest's Avatar
hightest
Thanks Bob,
I might just take you up on the info offer!
To 4L60E and FI
