NOS Question
Old Nov 16, 2005 | 01:00 PM
Cali17's Avatar
Cali17
From: West Hollywood California ! Now Miami, Florida
Default NOS Question
I have a 1999 Hardtop FRC .. with a halltech intake and i would like to have a dry kit with a 100 or even more ... shot ......... Looking for some of your wisdom ... what are my options i am brand new to NOS.
Thanks for your help
Old Nov 16, 2005 | 02:48 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Most will tell you that over 100 shot you should go wet.
Old Nov 16, 2005 | 04:52 PM
Cali17's Avatar
Cali17
Default Nos
I have heard its safer to go with a dry kit,..... why is this so ??
Old Nov 16, 2005 | 05:01 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Define safer.
You're safer because you have pretty much zero chance of fuel puddling in your maifold and blowing your hood off and burning your car down with a dry shot.
You're not safer because if you over do the shot (something that almost certainly IS NOT gonna happen at 100 or 125 hp levels) you could run lean and damage your motor).
Old Nov 17, 2005 | 12:51 AM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I like the dry. do a search over the last couple moths and there is plenty of info on the dry thing. If you want my personal opinion pm me.
Robert
Old Nov 17, 2005 | 12:54 AM
Robert56@RNS
Collections Hold
Where ya been, haven't seen ya around for awhile?
Robert
Old Nov 17, 2005 | 01:34 AM
Cali17's Avatar
Cali17
Default Pm
PM robert
Old Nov 17, 2005 | 01:35 AM
Cali17's Avatar
Cali17
Default Safer
Yes that is what i fear the most my engine just dying ..or burning up ..etc... so...........with that in mind dry or wet ...i think i should only go with 100 shot.......for now
Old Nov 17, 2005 | 02:08 PM
Cali17's Avatar
Cali17
Default ttt
ttt
Old Nov 17, 2005 | 03:58 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Robert
Got tired of arguing the wet vs dry with ya...
Been working like a dog.... school and work has been keeping me really busy... Im back though....
Old Nov 18, 2005 | 08:27 AM
sqeznbi's Avatar
sqeznbi
i look at it this way , when the oxygen sensors send signal to computer to ritchin the mixture you already have a lean condition in the cylinders. wet kit use rpm window switch and tps switch and there will be no puddling.
Old Nov 18, 2005 | 12:04 PM
rsxmanjoe's Avatar
rsxmanjoe
I would go with the NOS 5177 Kit. comes with a 15lb bottle, fuel pressure safety switch, wot switch, 2 foggers, and everything else you need. Its a good kit and its only 550 bucks
I like the dry kits for anything up to a 125 shot. For a dry kit to fail your MAF would have to fail which i dont think will happen anytime soon
Old Nov 18, 2005 | 01:05 PM
Cali17's Avatar
Cali17
Default Thanks
Great thanks for all your help .. i was researching as well last night and through what you all have been saying i am going to go with the NOS 5177 dry kit with a hundred shot ... also can this bottle fit in my trunk storage compartment .. , i have seen this done . but am not sure if the NOS 5177 kit would fit .. there, i want to be as descreet as possible.
Old Nov 18, 2005 | 01:08 PM
Robert56@RNS
Collections Hold
Someone correct me if I am wrong. O2's are out of the picture for adjusting fuel mixture at wot, it's the Power Enrichment multipler that controls a/f. Ther is also Fuel Adder vs IAT for adding an additional multipler on top of PE multiplier. It's temp based and when spraying your way cold so you can add an addition multiplier (read: rich) at temps you won't see n/a. Part of the two tunes in one that the dry can do. Timing also (write up in my web on how to pull timing on spray only).
Robert
Old Nov 18, 2005 | 03:28 PM
rsxmanjoe's Avatar
rsxmanjoe
the problem is the bottle is a 15 lb bottle. I have mine positioned in the middle of the trunk, with the valve pointed towards the front of the car. The bottom of the bottle sits at the lowest point of trunk, making the setup pretty clean.
I wouldnt recommend going with a smaller bottle since a 100 shot takes alot of nitrous and you dont want to be filling up all the time.
Old Nov 18, 2005 | 04:04 PM
X-ZZ4's Avatar
X-ZZ4
Oops.....nevermind my original post.....just saw you had an FRC.....
Old Nov 18, 2005 | 04:13 PM
Robert56@RNS
Collections Hold
Pics in my web on a couple set-ups. I agree, stay with the 15pounder, you'll run more consistant longer.
robert
To NOS Question
