Gauges
Old Nov 25, 2005 | 01:41 AM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
Default Gauges
what gauges is everybody running and what brand!! i have found some that i might pick up but first, i wanted to see what everybody is running!!
thx frank
Old Nov 25, 2005 | 02:16 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Gauges
Autometer
Old Nov 25, 2005 | 09:05 AM
1 Nasty Z's Avatar
1 Nasty Z
Autometer Cobalt
Old Nov 25, 2005 | 09:39 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Originally Posted by 1 Nasty Z
Autometer Cobalt
Old Nov 25, 2005 | 09:56 AM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Wideband AFr
Boost
Fuel Pressure
Old Nov 25, 2005 | 10:14 AM
DDSLT5's Avatar
DDSLT5
Autometer Nexus
They are electroluminescent, and you can choose mulitple color schemes. They have a max/min setting, so they will turn bright red when you exceed a preset value. Also, you can datalog with them, and replay many minutes of values, along with the maximum total value.
Old Nov 25, 2005 | 10:17 AM
Former Vendor
Did you have to glue the a-pillar vent piece in or did it snap in?
Old Nov 25, 2005 | 10:26 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Autometer Phantom white background for a white car mounted on the A-pillar.
Old Nov 25, 2005 | 10:28 AM
ProtoVette's Avatar
ProtoVette
Originally Posted by DDSLT5
Autometer Nexus
Nice. Where did you get them from and how much do they cost? Do you just ahve to install the gauges, or do you also have to have some type of controller to hook them up to?
Thanks,
Chris
Old Nov 25, 2005 | 10:48 AM
DDSLT5's Avatar
DDSLT5
Snaps right in place - you just pop it off the old a-pillar.
Old Nov 25, 2005 | 10:52 AM
DDSLT5's Avatar
DDSLT5
Thanks,
Chris
Yes - it has a controller - it is akin to a wired remote - it sits in the console in my car - just pop open the armrest, and there she is - fits in the palm of your hand. The wire runs through the trans tunnel cover area, across the dash and into the a-pillar area. Cost is high - check jegs or summit (go to www.autometer.com for the part number of the nexus gauges you wish to have, then plug that into jegs or summit website), I think one was $250 and other was $150 or something like that. The alarm feature has already saved my engine, as my boost controller overshot the high boost when I first tried it, and the boost gauge went bright red, and I got out of it - made 22 psi of boost at 3500 rpms!
Old Nov 25, 2005 | 11:33 AM
ProtoVette's Avatar
ProtoVette
What pillar pod are you using? Is it the Autometer one? How did you attach the pillar pod to the car?
Sorry for all the questions, but your information is quite helpful!
Thanks again,
Chris
Old Nov 25, 2005 | 01:10 PM
MissZ06's Avatar
MissZ06
Go with Defi Gauges, they cost a little more, but look alot better than Autometer.
Old Nov 25, 2005 | 01:48 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Autometer Cobalt
Old Nov 25, 2005 | 02:36 PM
DDSLT5's Avatar
DDSLT5
Thanks again,
Chris
I had LPE do the attaching, but I'm pretty sure it just snaps in place. Here is a pic:
And here is the part #: Dual Pillar (Black)
Product #
12192
Application(s):
1997-2002 Chevy Corvette
Old Nov 25, 2005 | 02:38 PM
DDSLT5's Avatar
DDSLT5
The Defi Gauges are electroluminescent as are the Nexus Autometer gauges. Did you see my post above?
Old Nov 25, 2005 | 02:52 PM
mdhmi's Avatar
mdhmi
Autometer phantom. Boost and fuel.
Totally unnecessary IMO. Almost never look at them under boost, although they do look
Mark
To Gauges
Old Nov 25, 2005 | 03:01 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Mark
Gauges don't do you much good when you are trying to DRIVE.......................someone should come up with a warning system hooked to your ***** with a 120volt shock...........that should do it
Old Nov 25, 2005 | 03:47 PM
DDSLT5's Avatar
DDSLT5
Remind me never to drive in your car! The Nexus gauges are great - yes, you rarely stare at the gauge while driving hard, but seriously, most traffic is either so thick or non-existant, and it is fun to see just what level of boost you're making. I almost always watch to see how much boost I'm making, whether it is the C5 or my little Ford Probe Turbo. For instance - the C5 makes 6 psi of boost at 1500 rpms in 6th in the cold weather!! Pretty sweet!
The other bonus is that if you exceed a preset limit, the whole gauge face turns red, and you catch it in your peripheral vision, and you get out of the throttle. Works like a charm!
Old Nov 25, 2005 | 05:55 PM
wannabe-psi
i think im going with either the defi d series or the greddy 60mm peak and hold. hhhmm!
