please help,need traction
Old Dec 12, 2005 | 03:11 AM
c5wolf's Avatar
c5wolf
Default please help,need traction
I have a just completed A@A with 740 hp and over 700 hp,6spd, and my 18 inch drag radials are useless.I am thinking about going to a 16 but is there a way to go 15 on a 97 c5,big props to my idols steath and paul zo6.who is running the best combo with a irs and a stick because this hp is useless right now.
Old Dec 12, 2005 | 03:19 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Like Paul Major did, you would have to redue the entire rear end, suspension and go with smaller rotors (mounting brackets) to clear the 15" rims on a Corvette.
The 16" CCW rims will barely fit.
Old Dec 12, 2005 | 03:27 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Personally, I think you will mod your car useless if you do that. Dont go changing your wheels/tires so drastically that it completely degrades all other capabilities of the car. There is a LOT of us here that have 700+rwhp. Your definately not alone. You just have to learn to use the throttle. Keep the 18"DR's.. Maybe you can switch to another brand. But if you go swapping you wheels/tires for a set of 15/16" tires, the only fun you'll have is light to light with all the ricers.
IMHO
Old Dec 14, 2005 | 01:10 AM
c5wolf's Avatar
c5wolf
thanks but should I go at least to a 17 and what tire should I run?
Old Dec 14, 2005 | 05:22 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Stick with Drag Radials (18's)... what PSI are you running them at?
I keep mine at 18# on the street and 10-12 for the track.....
How old are your radials... they only have a shelf life of about 6 months before they start to harden up.
Old Dec 14, 2005 | 09:16 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
please view
http://forums.corvetteforum.com/show...13&forum_id=86
17 tire no skinny no soft shock no removal of f. sway bar
at 145 car was dead staight
To please help,need traction
