Question on MAF
Old Dec 31, 2005 | 12:16 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Question on MAF
Im heading back home tonight, Im driving around 50-60 and get on the throttle about 1/2 to 3/4 of the way..........after that, car is running like crab, get to Arnold's and he noticed the MAF sensor cut in half.........Is this unusual?????? Im confused?????
The only mod I did to the car is change the pulley to the D1SC from a 3.85 to a 3.70 and change stock radiator to a Dewitts.
Can the pulley difference make the difference that I need it to re-tune car before getting on it..........................
Old Dec 31, 2005 | 12:30 AM
blu00rdstr's Avatar
blu00rdstr
I've heard they do split. Andy glues them together and it works fine.
Old Dec 31, 2005 | 12:50 AM
MIKE-C5's Avatar
MIKE-C5
Normal to split under boost..............
Old Dec 31, 2005 | 02:11 AM
blu00rdstr's Avatar
blu00rdstr
Yes
Old Dec 31, 2005 | 11:00 AM
QuickSilver2002's Avatar
QuickSilver2002
You might want to verify that your BOV is working correctly. They can split under boost, but mine never did. The pressure spike as the TB closes is probably when it happened. It also depends on where you had it positioned.
Old Dec 31, 2005 | 12:49 PM
MIKE-C5's Avatar
MIKE-C5
Thats exactly when it happens when the TB closed............I will check the BOV
Old Dec 31, 2005 | 03:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Mike, Good to see that the car is out and running again
Old Dec 31, 2005 | 04:06 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I blew 2 apart before I went with a bigger BOV..
Old Dec 31, 2005 | 05:27 PM
MIKE-C5's Avatar
MIKE-C5
Which BOV did you use.........Andy sells one for about 300.00
To Question on MAF
