What angle spark plug boots ...PTK setup
Old Jan 2, 2006 | 07:47 PM
Tomulrich's Avatar
Tomulrich
Default What angle spark plug boots ...PTK setup
I need to make custom plug wires for my PTK setup. What angle plugs wire ends are needed to give the best clearance at the header/spark plug. Not worried about the coil side (relocating them).
Thanks for the input
Tom Ulrich
Old Jan 2, 2006 | 08:22 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Tom Ulrich
use stock angle, straight
tom where do you plan on locating your coils?
Old Jan 2, 2006 | 08:37 PM
Tomulrich's Avatar
Tomulrich
I am using the lingenfelter battery relocation kit. I will be locating the passenger side coils where the battery used to be. The drivers side will be mounted by the inside fender. I have allready mounted everything....send me an email and I can email you pictures.
So straight plugs will give me the best clearance.....!!!!!
Tom
Old Jan 2, 2006 | 09:33 PM
NICK YOSKIN
St. Jude Donor '08
Tom
yeah if the 90* is to short the thick azz flange will interfear.
i guess your going to cut custom length wires
my email is yoskin@comcast.net
i need to get 6l80e to work...tom youll be second!
Old Jan 3, 2006 | 02:24 AM
AVB's Avatar
AVB
Straights will be fine but the adjustable ones are what I use. Sounds like you've put the coils in locations similar to mine.
Arnel
To What angle spark plug boots ...PTK setup
