Boost Gauge help
Old Jan 19, 2006 | 08:37 AM
Crunchking's Avatar
Crunchking
Default Boost Gauge help
My son installed a combination boost/vacuum gauge for me on my 98 A4. The tuner needed the gauge so he could finish the tune after we installed A&A's PISC. All we are getting is vacuum readings. We hooked up the hose at the back of the engine where we supposed to. Any thoughts??? I'm sure it is something dumb.
TIA
Dave
Old Jan 19, 2006 | 08:39 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
It reads vacuum when the car is at an idle and cruising.. it only goes into boost when the car is actually boosting. So take the car out and step on the gas pedal and watch the gauge go the other way.
VR
Old Jan 19, 2006 | 08:49 AM
Crunchking's Avatar
Crunchking
Default Thanks
I tried revving the car up in the driveway, and it is not reading any boost. However, everything is hooked up and it is blowing some serious air into the engine. I am picking the car up today from the transmission shop. I had a level 5 installed. The original transmission had LOTS of miles and only lasted TWO days after the engine was up and running.
Old Jan 19, 2006 | 09:11 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
It won't show boost revving it in your driveway-there is no load on the car. If you take out for a drive get on it you will see boost.
Old Jan 19, 2006 | 09:24 AM
Crunchking's Avatar
Crunchking
Default Thanks
I figured it was something dumb. I will try it out tonight.
Old Jan 19, 2006 | 10:26 AM
DDSLT5's Avatar
DDSLT5
You could just do a smokey burnout in your driveway - THAT would show boost!
Old Jan 19, 2006 | 11:37 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Yeah Done that one
Old Jan 20, 2006 | 11:03 AM
Crunchking's Avatar
Crunchking
Default Got boost
6 lbs of boost. Yippie!!!!!!!!
Old Jan 20, 2006 | 11:05 AM
vetterdstr's Avatar
vetterdstr
VR
To Boost Gauge help
