Battery Relocation question???
Old Feb 3, 2006 | 09:55 AM
Face's Avatar
Face
I would be using a electric water pump so I don't have a meltdown. So I guess this battery wouldn't be enough then?
Old Feb 6, 2006 | 04:36 AM
kawboy5792's Avatar
kawboy5792
Originally Posted by auctiondepot
I'm Putting the battery in the passenger side rear compartment also. I got a 500 amp gel battery that is a tight fit. The problem with this location is that there is no convient structural support, just the fiber glass pocket. I'm going to try and build an Aluminum box for the battery and with angle, support it to the side and rear frame rails. The last thing you want is a 30lb battery floating around the cabin during a catastrophic event.
use 1-0 welding cable for the leads to the front starter. There is room to route through the wheel well and under the door frame.
The LPE example in the center pocket has adequate access to structural framing, however in this location the CD player has to be relocated.
LPE instuctions for battery relocation
My first attempt at the Battery box:
My first attempt at the battery support
Cable is routed through wheel well to rocker panel.
Battery working in passenger compartment
I like how invisible this setup would be! Im wondering though, have you ever had your car out to the track? Would they allow this because its a gel battery, or no?
Old Feb 6, 2006 | 06:05 PM
auctiondepot's Avatar
auctiondepot
I dont think so,
The rules I saw suggest that this would have to be sealed , and there needs to be a 100% kill switch in plain view on the rear face.
Here is the info I found.
All batteries must be securely mounted. Batteries may not be
relocated into the driver or passenger compartments. Rear firewall
of .024-inch steel or .032-inch aluminum (including package tray)
required when battery is relocated in trunk. In lieu of rear firewall,
battery may be located in a sealed .024-inch-steel, .032-inch-aluminum,
or NHRA-accepted poly box. If sealed box is used in
lieu of rear firewall, box may not be used to secure battery and
must be vented outside of body. Relocated battery(s) must be
fastened to frame or frame structure with a minimum of two 3/8-
inch-diameter bolts. ("J" hooks prohibited or must have open end
welded shut.) Metal battery hold-down straps mandatory.
Strapping tape or Electrical zip ties prohibited. Stock unaltered battery
boxes / trays with OEM hold downs permitted only in stock location
Master Disconnect Switch:
Whenever a battery is relocated to the trunk, the vehicle must be equipped with an external disconnect switch. This switch must be clearly labeled and immediately disconnect the positive side of the battery. To determine if the switch operates properly a tech inspector will turn off the switch with the engine running. If this action does not shut down the engine then the switch is wired improperly and the vehicle shall fail the inspection. Drivers should ensure the alternator charge wire is routed to the battery side of the switch. This isolates the alternator from the rest of the electrical system. Drivers should check with the switch manufacturer to ensure it is properly installed.
Old Feb 6, 2006 | 09:42 PM
Tomulrich's Avatar
Tomulrich
LPE kit will not work on 97-98 C5 vettes
Tom
Old Feb 7, 2006 | 09:44 AM
Face's Avatar
Face
Tom
Correct, we have the stupid ABS box in the way.
Old Feb 7, 2006 | 12:23 PM
TriniJoe's Avatar
TriniJoe
Late 98's have the ABS box in the front. I have a late 98, borned 04/98, and the ABS box is up front.
Old Feb 7, 2006 | 02:17 PM
kawboy5792's Avatar
kawboy5792
Is the LPE kit IHRA/NHRA legal?
Old Feb 8, 2006 | 11:06 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
It is and isn't. It has the right stuff excepte the kill switch mentioned above
Old Feb 9, 2006 | 12:05 AM
kawboy5792's Avatar
kawboy5792
I wont have my car near me for another few weeks, does anyone have the dimensions of the right side cargo well so i can order a battery/box to fit?
