LQ9 head question.
Old Feb 19, 2006 | 08:23 PM
TaTommy888's Avatar
TaTommy888
Default LQ9 head question.
I have a turboed LS6. I was thinking about installing a set of LQ9 heads to drop the CR.
What else do I need? Are these heads complete (valves/springs)? Are the springs good? Are the valve stems hollow like the LS6 valves? Should/can the springs be swapped?
You get the point! I need info!
Thanks guys!
Tommy
Old Feb 19, 2006 | 08:30 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Thanks guys!
Tommy
The heads will be as complete as you buy them. The springs that are true factory springs are NOT going to work, but you can use your yellow LS6 springs on them. The vavles are not hollow stem either.
I just got and installed a set of 225 dart heads. They come complete and are a direct bolt on. Slight modification of the rocker stand is required and will only take you 10 minutes with a grinder. These heads were less than $1300 shipped to my door. The pockets are CNC cut, 225 intake with 2.05, 1.60 stainless valves.. they are VERY nice. Price is nice also. They are not going to help your compression situation though, they are 62cc. You can use a thicker head gasket to lower your compression, but I would recommend you just wait until you build your motor.
If you are just going to try to lower your compression the easy way, then those heads will work for you and they are pretty cheap.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Feb 19, 2006 | 08:41 PM
TaTommy888's Avatar
TaTommy888
Yeah, the goal of installing these heads is to inexpensively lower my CR (and hopefully increase reliability!)
The Dart heads you mentioned sound great for the price, but they will not help my situation (as you mentioned!)
So the valves are not interchangable for LS6 to LQ9? The ideal situation for me if to buy a set of bare LQ9s and use the valves and springs from my LS6, but it doesn't seem like that is the case.
I don't want to experience any valve float of resonation problems. The LS6 heads don't seem to have these issues. I'm just getting a little worried about the CR, and my never-satified attitude!
Thanks for the info.
Tommy
Old Feb 19, 2006 | 10:23 PM
BLOWNZO6's Avatar
BLOWNZO6
You would have to check with one of the head guys on here on the valve specs. I would ASSume they are the same length and size.. but that would be way to much. From a valve perspective you would be fine. I am pretty sure the springs can just be swapped.
You can get a set very resonably. I just sold a brand new pair for $550.
Old Feb 19, 2006 | 10:30 PM
TaTommy888's Avatar
TaTommy888
Did you have the 12572035 castings?
I checked a bunch of GM parts sites and that part number is no where to be found. I was trying to get a price on stock heads...
Thanks again for the info.
Tommy
Old Feb 19, 2006 | 10:33 PM
BLOWNZO6's Avatar
BLOWNZO6
The ones I had were the "317" heads.
I did not have the full casting number written down.
I can find the number for you probably though if you need it.
Old Feb 19, 2006 | 10:48 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I bought a brand new pair from Nick (BlownZ06) and they have 317 castings number. I'm in the middle of moving house, but I can look for casting numbers on Friday.
EG
Old Feb 20, 2006 | 01:50 PM
Jesse_Boyer's Avatar
Jesse_Boyer
I have a set of 6.0L heads and they have 317 cast into them... Those are what you're looking for if you want 6.0L (LQ9) heads.
Old Feb 22, 2006 | 03:54 PM
rking's Avatar
rking
I have a set for sale! PM me if your interested.
Old Feb 22, 2006 | 05:36 PM
M_T_0's Avatar
M_T_0
if you are ditching the ls6 heads and going to the darts with 62 ish cc chambers you will be lowering the CR to about where the ls1 is, 64 ish on the ls1, I do not know how much boost you are running but I would stay away from the lq9's unless you are going to run past 12psi.
you will lose power due to the lower CR and I'm not sure how much reliability you will be getting. also the dart heads with the 3/4" deck will be better for you down the road if you forge the botom end and get dished pistons.
JMO
More Than Zero
Old Feb 22, 2006 | 07:52 PM
Jesse_Boyer
i believe you'll only lose about 3% of your HP for every full point drop in CR (that's from memory and could be completely wrong).
If my memory suits me correctly, that's a small price to pay for additional boost up top.
Old Feb 23, 2006 | 01:07 AM
M_T_0's Avatar
M_T_0
I do not think that he has give any info on what boost he is running or how much he is going to shoot for, so with out that info I do not think that we can answer any of this.
JMO
More Than Zero
Old Feb 23, 2006 | 08:03 AM
TaTommy888's Avatar
TaTommy888
JMO
More Than Zero
I did not plan on running more than 7 lbs of boost.
My only reservation with going with the LQ9 heads is if I have to replace the valve springs. Then it can become expensive. The only reason for adding LQ9 heads is to lower my compression a bit which adds a margin of safety without spending a lot of money (but not doing it "cheap") if that makes any sense!
When I have more time I will look into this further. Thanks guys.
Tommy
Old Feb 23, 2006 | 10:36 AM
M_T_0's Avatar
M_T_0
Tommy
for 7psi IMO there is NO reason to go larger that about a 64cc chamber and even the stock ls6 will be fine again this is IMO. I'm running 12psi on stock ls1 cr and bottom end.
More Than Zero
Old Feb 25, 2006 | 09:52 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Tommy
The patriot gold springs perform great and fit without any machining to the heads and are about $275.00. That's pretty affordable and is the way you want to go if you do the LQ9 heads to drop your compression. I am thinking about doing the same thing!
Old Feb 25, 2006 | 02:14 PM
Jesse_Boyer
my only reservation with switching to the LQ9's is the "where will it end" factor.
Once I pull the heads/intake, I might as well replace with my LS6 intake, LQ9 heads, and Patriot Golds. Then, what about the cam, pushrods, timing set, oil pump... etc...
it'll never end... So, I'm thinking i'll just tune it with the stock Longblock.
Old Feb 25, 2006 | 03:45 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
[QUOTE=Jesse_Boyer]my only reservation with switching to the LQ9's is the "where will it end" factor.
so funny but sooooooooooooo true!
Old Feb 25, 2006 | 04:27 PM
YELLOHHH's Avatar
YELLOHHH
It never ends. Ever.
Old Feb 25, 2006 | 05:14 PM
Jesse_Boyer
exactly! With that said, I'm going to tune my STS setup for 10psi on a 100% stock LS1.
To LQ9 head question.
