Oil separator
It's before the blade and I already knew which way the vacuum was going I was really just asking if it could reverse flow. If you pull the hose and put your finger over it, you can tell that the vacuum is coming from the hose side (valve cover) and not the throttle body side.
Do you think that vaccuum that you're saying is getting created at high air flow (rpm) could overtake the vacuum from the other end of the equation (at the manifold) at that same high rpm thus causing a reverse flow? That's my real question...
Arnel
I have mine mounted on the head but I've read where it's better to mount them further away from the heat like to the frame at the front passenger side corner (under the hood).
The PCV valve will fail.....The PCV valve was not designed to withstand back pressure, it was designed to allow unobstructed flow OUT of the CC.
We had one guy who could blow 3 psi!
Still not sure about needing a check valve in addition to the PCV valve.
Not a lot of time on my setup (only 2000 miles), but so far the PCV valve is preventing backflow and holding up fine with 10 lbs boost, and a lot of time spent under boost.
At full throttle, there is almost no vacuum in the manifold where the PCV valve connects, and almost no pressure differential between that and the air supply connected to the throttle body, so blowby could enter the engine through both hoses.
On a FI application, the PCV is closed under boost, so all the blowby must exit somewhere else. Can't keep the supply side connected to the throttle body, or you'll pressurize the crankcase. On mine, the hose that normally goes to the throttle body is connected to the air filter, and that's where all the blowby goes.
So far, this hose is dry inside, but I think concerns about condensing fuel vapors etc. in the intercooler have merit. Best to keep the cooler clean, I would think.
Best thing might be the the oil filler breather a lot of guys have. Filtered air enters under vaccum, and blowby vents under zero vacuum or boost. The throttle body and air filter connection are eliminated, so there's no chance of oil mist or other vapors getting in.
I'll be putting on RoadRebel's custom high-tech super-secret oil filler breather next time I see him.
But dang it, it's not a jet boat!
It's a V-drive.
It's a V-drive.
