ls7 clutch
Old Apr 9, 2006 | 06:23 PM
creighton's Avatar
creighton
Default ls7 clutch
so far so good. just thought i'd give you guys on the fence a little heads up. last year after 1-2 highway pulls on a 100 shot the pedal would stick and i'd have to pull it up with my foot. put an ls7 in this winter with the same master and slave, i have an 04 so some people think it is the upgraded unit, but i did drill out the line.
today did some good n/a and 100 shot pulls and the clutch never had an issue knock on wood! pedal is in almost the same spot as before, maybe a little lower on the floor for release, but as expected pedal feel is almost identical to what i had before.
Old Apr 9, 2006 | 06:35 PM
chriswtx's Avatar
chriswtx
When I do a new motor I'm thinking I will do the ls7 clutch. So good to know..
Old Apr 9, 2006 | 09:02 PM
creighton's Avatar
creighton
yep, i would suggest doing something while the motor is out. the kooks make the clutch swap with the motor in the car soooo much harder than it needs to be. what kind of fp are you running chris?
Old Apr 9, 2006 | 09:03 PM
chriswtx's Avatar
chriswtx
fp??
Old Apr 9, 2006 | 10:04 PM
creighton's Avatar
creighton
fuel pump
Old Apr 9, 2006 | 10:07 PM
chriswtx's Avatar
chriswtx
K...I made my own set up. Running a Bosch 0 580 254 044 in parallel with the stock pump, aftermarket fuel rails, aeromotive FP regulator, MSD boost a pump and a return line back to the tank...very similar to the ECS fuel system
Old Apr 9, 2006 | 10:43 PM
lewishou's Avatar
lewishou
What's your rwhp with your current setup? I am debating between Cartek or LS7 clutch. Thanks.
Lewis
Old Apr 10, 2006 | 08:21 AM
creighton's Avatar
creighton
i put down 404 on motor friday. on a fat 150 shot with some nitrous activation issues i was at 540ish. i'll be strapping down again soon to get some of the spray issues sorted out.
Old Apr 10, 2006 | 10:57 AM
M_T_0's Avatar
M_T_0
I've had the ls7 clutch in mine for 3 months, hard pulls on the street and a few Drag strip starts and it is bullet proof so far, knock on wood(street tires only)
More Than Zero
Old Apr 10, 2006 | 08:04 PM
InSaNeKaMeL's Avatar
InSaNeKaMeL
how much does it cost? i have not seen its price?
Old Apr 12, 2006 | 02:28 PM
creighton's Avatar
creighton
check out les stanford or fitchner. it's right around $525
Old Apr 13, 2006 | 07:45 PM
FourG63 97GST's Avatar
FourG63 97GST
anyone has a part number? I work at the dealer. I'll like to see what I can get this for.
how does this compare to the textralia?
Old Apr 16, 2006 | 08:09 PM
blkonblk_c5's Avatar
blkonblk_c5
I did the LS7 clutch that I got from Gene and I'm very happy with it. but I did everything from the master and slave cyl. to the pilot brg.
Old Apr 17, 2006 | 04:23 PM
bernrex's Avatar
bernrex
I think its too early to say what HP the LS7 clutch is good to. Some owners of C6Z have modified to around 500 RWHP ... and are seeing slippage rather quickly afterwards. Apparently the clutch doesn't handle heat friction well and some are looking to replace it with other aftermarket products.
Old Apr 17, 2006 | 04:30 PM
creighton's Avatar
creighton
all i can say is it has been great for me so far. maybe it was the clutch maybe it was drilling out the hydraulics that solved the problem?
Old Apr 17, 2006 | 06:38 PM
pianoprodigy's Avatar
pianoprodigy
St. Jude Donor '12
LS7 clutch worked well for me when I was making 503/518 and is still working great now though the nitrous is gone.
My take on the LS7 clutch? If you want the most driveable clutch that you might occasionally take to the track that can handle 500 rwhp, get the LS7 no questions asked.
Old Apr 17, 2006 | 09:05 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
What about the recal on the 06 Z06-something about the flywheel?
To ls7 clutch
Old Apr 18, 2006 | 12:55 AM
rsxmanjoe's Avatar
rsxmanjoe
ive been running the clutch on my 02 z and have had no problems...I even put it through some nitrous runs the other day (currently making about 480whp/540wtq).....clutch held fine - no issues
Old Apr 19, 2006 | 04:25 AM
2MuchRiceMakesMeSick's Avatar
I know this clutch has been tested and holds up good south of 475twhp
Old Apr 19, 2006 | 04:50 PM
M_T_0's Avatar
M_T_0
it is holding like a champ for me (street tires only)
More Than Zero
