I'm building my engine in anticipation of a TTix install. I would like the power to be in the 650-700 rwhp range on 93 octane without using meth. I plan on having it tuned to that level and then left alone......no boost controller. Will the stock displacement (forged & AFR's) get me there or should I plan on going with a stroker?
If the 6spd drivetrain can be driven daily with 650-700 rwhp and remain healthy, we have the same goals.
I'm leaning to the STS, but I the jury is still out for me.
Look forward to hearing about your engine build.
91octane pump gas, and i do believe the meth was turned on as I wasnt present during the dyno runs.
Yano,
I've driven a s/c car at altitude (Twin Screw GTS) and you could definitely tell the difference... How does a turbo car feel at altitude and does it affect power as much?
i personally think the Turbo is a better power adder at altitude. My old SC setup was pretty fast, but nothing compared to my TTix.
The only time I have to compare is last fall we did a HPDE at PPIR, and I was able to completely lap the entire field on every 15-20 session, and that was with brakes that were dead after just a lap or two. So i had to take it easy.
There is a local guy with giant Vortech SC, a 408, NO2, and huge cam, heads etc etc. and my numbers were higher than his until his last set of mods.
