yank's 4l80e conversion
Old May 9, 2006 | 09:44 AM
  #61
Earl H's Avatar
Earl H
Originally Posted by STEALTH 99 C5
Alan , No disrespect to your ride but I'm not impressed by the t-400 yet , out of those 40 runs the majority are between 9.5 to 10.1 , my RPM 4L60E held up to over 35 runs between 9.8 and 9.6 and after approximately 10 runs below 9.5 it still didn't fail , I sent it back to him over the winter for a refresh for insurance .
I know you've been pacing yourself and getting comfortable with the speed and you've come a long way but as I've said in the past , I want to see a C5 with a T-400 make 40 passes in the solid low nine/high eight zone . It's really a matter of personal preference , and of course money , your happy with yours , good for you . Now throw that 10 rib belt on it and crank up the boost and test that trans .
If the RPM tranny has held up to that much abuse (35 or so runs in the mid to high 9's) and only had to do an annual rebuild, is there a reall advantage to this option (assuming that there are no issues and it does work problem-free as "assumed"), considering you will probably have to rebuild just as frequently. Sounds like there is no real upside considering the $15K insalled price and cutting up the car. I am running an RPM tranny as well and am especially interested to hear.
Old May 9, 2006 | 10:02 AM
  #62
slotsofun's Avatar
slotsofun
What about a 3 or 4 person group buy to bring the cost down
around 3,000 less per tranny. Yank would you be willing to do that?
Although now it seems that this tread has started to turn on you
a little.
Would any of you guys be interested in something like this.
Old May 9, 2006 | 10:11 AM
  #63
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
i dont care who builds these 4l60e the problem lies in the 3 4 clutch pack/band design and the long passage way for the 3 4 selniod. if my trans only needed to be rebuilt over the winter then i'd be ok w/that but....
my first one didnt last long as i ran wrong edit then the second one went with a WOT top end run...186mph. the third one didnt last long either...3 4 pack and band. maybe i need to send it to rpm instead...
does rpm run 9 plates and what are the tolerences? we tried to run nine plates but that means that you gotta run thin metals...that then can cause coning.
  #64
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
I don't know...."Hacking and Car" in the same sentence does not sound good to me
Old May 9, 2006 | 10:24 AM
  #65
NICK YOSKIN
St. Jude Donor '08
who says its gotta be hacked?
the earlier version needed more work to fit
Old May 9, 2006 | 11:56 AM
  #66
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Read: I have the means and the need for your product, but would not risk $15K and cutting up my car for an "unproven" (on my car application and for my intended use) system. Hopefully you will take this constructively from a current and potential customer. Put the system on the road for some long-term durability testing (maybe even Stealth's car for a racing season) and prove your design and the materials and find out what COULD go wrong. Just my .02 and its probably worth just that.
Cutting/ Hacking means the same to me
Old May 9, 2006 | 07:58 PM
  #67
STEALTH 99 C5's Avatar
STEALTH 99 C5
I never said it only has to be freshened annually , that depends on your power level and driving style . I sent mine back over the winter months to be freshened because the car was going to be down for awhile getting a roll cage and other safety equipment installed , sometimes I'll make 35-40 runs within one month , so the amount of times it has to be freshened during the year varies , if you make 25 runs per year , then you should only need an annual freshening , or maybe you won't need it freshened at all , everyone's driving style is different , I could go out and ruin a trans in one day at the power level I'm at if I constantly beat on it over and over , it wouldn't matter who built it , it's hard , but to help make driveline parts last in a street driven big HP C5 , you have to have a lot of self control , and know how to treat the car responsibly .
Old May 9, 2006 | 08:57 PM
  #68
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
Dead on. Once you get these cars up to the level of Mike's things like hot laps become foolish because even with tranny coolers you need to let the set up cool down between runs.
Mike - are you going to put a removable chute on the back? Mine is going on after the pro-10.0.
Old May 9, 2006 | 09:21 PM
  #69
STEALTH 99 C5
No , I'm going to " lift " at the top end and try and trap 149mph everytime . Seriously though , if/when I break 150 trap speeds , the removable chute will go on .
Old May 9, 2006 | 11:44 PM
  #70
NICK YOSKIN
St. Jude Donor '08
i have no problem with freshening every 12 months, even 8 months.
i'm pretty good at R&R trannies now! i can have tranny on the floor in 1.25 hours
Old May 10, 2006 | 08:06 AM
  #71
Tomulrich's Avatar
Tomulrich
I would jump on one of these units if it were 3000.00 off......Would you be interested in selling the parts minus the transmission. This would be for the do it yourself people....
6000.00 ...Ill take one now!!
Tom
Old May 10, 2006 | 10:32 AM
  #72
slotsofun's Avatar
slotsofun
Yea, Tom and you are going to need one of these with the power you
will be making!
Old May 10, 2006 | 11:30 AM
  #73
yankman's Avatar
0yankman
Former Vendor
Tom
You can send your Transmission (4l80-e) to us, but the Mods to the case, front pump assy, and new shafting that is needed plus machine time to fit up all of the custom adapters and hand alignment of all centerlines takes special tooling.
This is why we can not sell just a parts kit
If a good late model 4l80-e core (1998-2006) is sent in this will save about $900.00
and if you send a built race trans the savings to swap it over would be an added savings to you
Old May 10, 2006 | 12:02 PM
  #74
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
So I guess I will ask first. What would be the cost if you sent in a Built race trans to you for the labor, machine time ect??? I am saying out the door.
Old May 10, 2006 | 01:09 PM
  #75
STEALTH 99 C5
Old May 10, 2006 | 01:15 PM
  #76
mdhmi's Avatar
mdhmi
Probably $8-9K.
Mark
Old May 10, 2006 | 02:32 PM
  #77
yankman's Avatar
0yankman
Former Vendor
If the transmission is in a useable state (new GM, aftermarket rebuild or low time unit) build the package will be in a $8000.00 to $8700.00 window
Thank's for the ?'s
