are there any known kr fixes for C5's, I've got a 99 and I seem to get a max kr spike right into boost, running 100 octaine now, 10*timing, and 11.1afr, wasnt happening before I went 2bar, here's a link to the longer version of whats going on http://www.ls1tech.com/forums/showthread.php?t=505381
any help would be great.. there's screenshots and a link to files on that page..
I was getting some knock from the burst knock table.
Check there as well.
If that is the case bump the delta air for the burst knock up.. stock on my car was 0.04, I went up to 0.20 as I was seeing changes of about 0.17 with the turbos.
Someone found it for me.. hope that solves it for you.
Yea, bust knock is common when first setting up an SD tune since your airflow#s can have large deltas. I don't remember it showing up in the normal KR pid, but there could be one that combines the two.
Anyway, just 0 out the burst knock table and see what happens.
burts kr is more of a tip thing not were your at though
Burst Knock can happen during boost transition if you don't have a real smooth VE table. But is sounds like the burst timing pulled is set to 0.
Have you tried running more timing. What happens when you run it at about 15* in that area?
I'm guessing this is either false KR or something bad is going on. How is your PCV setup. It can cause some nasty Knock problems. Also check all your injectors and read your plugs
