Sensor relocation questions.
Old May 28, 2006 | 04:17 AM
MawneeC5's Avatar
MawneeC5
Default Sensor relocation questions.
My Supercharger install is winding down, but I've run into a dilema.
On the old air intake system, there was a sensor installed in the flattened coupler, Where should I relocate this to?
Also there was a small tube stuck in it that seems to go to the fuel rail, again where should this be relocated to ?
Thanks in advance for an advice
Old May 28, 2006 | 02:36 PM
MawneeC5's Avatar
MawneeC5
Anyone ?
Just need to know if they should go on the boost side or the intake side
Old May 28, 2006 | 04:16 PM
Skunkworks's Avatar
Skunkworks
I’m assuming the flattened piece your referring to is air bridge and that’s your IAT (inlet air temperature) sensor. That should be located in inlet tract, before throttle body and after intercooler (assuming centrifugal supercharger Paxton, Procharger or Vortech). If it’s a Maggie then some mount in manifold (below supercharger body) while LPE mounts in inlet duct.
As far as tube going to fuel rail??? No such creature maybe take a better look and report back.
Good luck,
Mike
Old May 28, 2006 | 07:31 PM
xlr8shn's Avatar
xlr8shn
Old May 28, 2006 | 07:35 PM
xlr8shn's Avatar
xlr8shn
Small tube that goes from air intake to the fuel rail is the vaccum tube from the intake to the 97-98 fuel pressure regulator. You will need to tap into the vac from the brake booster line. (or whereever you tap into the vac for the blow off valve and boost gauge...)
IAT is in the pic I posted above...
Old May 28, 2006 | 09:01 PM
Cscokd's Avatar
Cscokd
Originally Posted by xlr8shn
Nice clean looking installation Hale! Hope mine turns out as nice.
John
Old May 28, 2006 | 09:19 PM
MawneeC5's Avatar
MawneeC5
Great, thanks for the answers guy!
Back to work for me
Old Oct 4, 2011 | 11:09 AM
brandtdavis's Avatar
brandtdavis
I know this is old, but it's the very same question I have. Does anyone have a pic of where you put your IAT? I'm installing STS on a 97 and need to relocate.
Old Oct 4, 2011 | 03:24 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I relocated mine in the intake behind the TB.
Old Oct 4, 2011 | 10:58 PM
brandtdavis
[QUOTE=rclinton;1578872824]I relocated mine in the intake behind the TB.
So you drilled into the intake manifold? I was thinking of drilling the side of the air bridge and sealing it really well.
Old Oct 5, 2011 | 12:04 AM
tony75A's Avatar
tony75A
Run the typhoon IAT sensor, it uses NPT thread and it won't pop out under boost. It uses the same harness connector too. I got mine for about $10.00 and welded a bung on the charge pipe.
Old Oct 5, 2011 | 12:23 AM
Chrisrokc's Avatar
Chrisrokc
I am not sure what parts were used. My tuner did this part for me (I forgot). I believe it is a F-body air intake sensor and rubber grommet. You can see it in the picture below.
Old Oct 5, 2011 | 05:18 AM
MawneeC5's Avatar
MawneeC5
Wow this brings back memories
Old Oct 7, 2011 | 08:47 PM
brandtdavis
So now I'm hearing I should use the 2004 z06 style maf with caspers plug and forget my IAT sensor? Any opinions on this??
Old Oct 7, 2011 | 09:01 PM
p1bz's Avatar
p1bz
I am running the Caspers plug. It states that it is for a GTO, but it works fine for our c5 vettes. You still need the sensor, it's 15 bucks at Autozone, 95 camaro sensor. The Caspers plug just takes care of the splice for you, and looks nice and clean.
Old Oct 7, 2011 | 09:08 PM
95BlueBomber's Avatar
95BlueBomber
I used the stock grommet and drilled a hole with a step-up bit in the side of my A&A duct.
Old Oct 7, 2011 | 09:11 PM
95BlueBomber
Also if this is a return style fuel system I think the line you are talking about is the hose that goes to the regulator on the fuel rail. You can use a tee from the back of the intake and run a vacuum line to it from there.
To Sensor relocation questions.
Old Oct 7, 2011 | 11:02 PM
p1bz's Avatar
p1bz
Sensor is a Wells SU107. I can't remember if it was Autozone, or O'reilys I got it from, but good luck. The Casper harness and this sensor will do it.
Old Oct 7, 2011 | 11:20 PM
brandtdavis
I have the 92-93 typhoon sensor still in the box.
The way I was being told was I would get the 04 z maf which has the IAT built in. Then i dont need the iat sensor at all. Then the caspers plug takes my 3 pin maf plug to a 5 pin style.
Also I agree ny return style 97 fpr needs a vacuum line to it. Can I tee in where my boost.gauge, bov, wadtegate go near the brake booster??? Thanks for all thr help.
Old Oct 7, 2011 | 11:25 PM
p1bz's Avatar
p1bz
If you have the old 3 pin, then just use it as is, and relocate the temp stock temp sensor into the intake. I drilled mine right behind the throttle body just like in the pic in this thread. What I am saying, is use your stock MAF and your stock temp sensor, but just put the temp sensor in the intake manifold. Done.
