Help me pick out a clutch...
Received 1,195 Likes
St. Jude Donor '15
Welp, my new setup is going to be as follows:
LS6 (stock displacement) based engine with forged internals and designed to be very nitrous friendly. It will be running at least a 200 shot. I will be running stage 2e heads from MTI and a G5X3 cam and longtube headers.
Right now I'm on a STOCK couple clutch, not even the Z06 one... Obviously that is NOT going to last at all. What is the latest and greatest in clutches?? I'm guessing I should be somewhere around the 600HP range. Do I have to replace the master cylinder?? Seems like I read about an adjustable cylinder one time. Obviously I want to do the clutch while I have the motor out to save me some labor.
I drive this car A LOT so drivability is a major concern to me. It will see the track a few times a year but not all that often as there isn't really one close to me. Thankfully it is no longer my daily driver so I can do mods like this...but it has to be reliable and easy enough to drive so that it COULD be if it had to be. Any help is appreciated.
I've looked at the McLeod, Exedy and Textralia and so far the Textralia is looking like my best bet. Anyone agree, disagree??
Thanks guys for any help!!
Carson
Carson
St. Jude Donor '15
I'll look into it...good idea, I hadn't thought about using that one yet.
Does the LS7 clutch fit a LS6?
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Been running the Cartek for a few months now. It has also taken a lot of abuse. Still works as good as the day I put it in and it is supporting a lot of horsepower.
Life Time NCM #2196
I have a RPS setup in my car and it has seen it's share of abuse in the 3500+ miles I have on it. When new it was stiff and after 4 or 5 heat cycles it is just a little stiffer than the stock. I have been happy with the clutch so far
Originally Posted by chriswtx
LS7 clutch fits the LS6 fine. That is what I am planning on using with my new motor.
Be careful with this choice. IMO ... its not yet proven itself.
On launches at/above 4000 REVS ... the clutch hangs, and is prone to glaze. The strip pros are sending up the redflags on it.
Let the buyer BEWARE
Yeah, but he said he wanted a good street clutch for everyday stop and go traffic not a race clutch...MTO is using the LS7 clutch localy without problems even at the drag strip...
Street action can be very tough on clutches
You can get an LS7 clutch for $500 with a new flywheel. My stock clutch is holding fine after 2 different superchargers Magnacharger and now ECS Paxton at 617wrhp/572rwtq and 25-30 passes at the drag strip and 2000+ miles on the street. Its all how you drive and not getting the stock organic disc too hot and glaze it over...A tosted clutch is usually 90% driver error...
Cruise-In IV Veteran
I've been running an RPS clutch for about 10 months now with some serious street driving and it's holding up just fine.
I've also drivin to Florida and Georgia from Jeresy with 588 RWHP with NO problem!!!
St. Jude Donor '15
Thanks guys. The LS7 clutch is looking like a good option along with a few others.
I drive over 20K miles per year on average... That's why I'm thinking the LS7 clutch is a good bet. It was designed and tested for high mileage use..who knows about the other units. I'm sure they can and do handle the power just as well but I have no idea how they will hold up long term
Originally Posted by bernrex
Perhaps ... but, why accept that risk ... when for the same money you can get a Cartek Level 7 ... very streetable and rated to 700 RWHP.
St. Jude Donor '07-'08
What about the new Spec stage 3+ . I had the stage 3 and it worked great, now with over 800hp i am going with the 3+. It has got to be the best bang for the buck if it can handle the power it says it can. 550 bux
