STS for Bragging ONLY??
I hope I do not come off as harsh, as I think it's a very creative system. But I have yet to see something that makes me say WOW, ie Nick with his ET and mph his first time out, Shinobi with his dyno numbers back in the day, LPE and all their accomplishemnts back in the day, etc.....
Anyone have anything real with the STS?
but if you do i would enjoy reading about it and i wont think your bargging
remember win or lose save the wave peace
I like the STS system. I think it kicks a$$
Cajundude is pulling 14.5psi, Steve. Just a "tad" more than your setup
I kinda have this special ability to destroy drivelines.......with stock power levels....
Cajundude's setup shows it has some potential but that is on a fully built 408 with all the goodies.
I'm still deciding if I want to do the Roll Bar and 5-point in my daily driver coupe. Doing all this, takes away from the stealth of the system.
If I don't ... its pointless to drive 200 miles ... only to get booted off the track after several runs.
Only CajunDude seems intent on going the hardcore route.
What you need is a ride in one. In Calif. there should be a number of locals that could give you an STS Experience.
Get your ride ... then come back and give us your review.
remember win or lose save the wave peaceturbo @ 9 psi 11.7 @ 129.98mph (Supra style
) approx 550rwhpprocharger @ 7 psi 11.1 @ 123mph approx 460 rwhp
procharger @ 13psi 11.4 @ 132mph approx 600rwhp
Hope that helps ya out.
I'll address some of the other comments seperately as well. Also,ome of you guys are a little overly defensive.
Braggin' is for beotches. Dyno numbers are worthless IMO as well. Track times are what counts. I can point you to my dyno sheets if ya really want to see them.
, the frist time it happen i thougt it was that **** i did in the seventys came back to haunt me
so i did it again thank god it was the turbos kicking in
right now my car is down lucky no.7 went out. but it's ok andy& charle hooked me up with a 346 FORGED SHORT BLOCK
eric at bottlefed is doing the install with a few other goodies. and when its done ill be glad to post some#s. peace and save the wave.If the system is such a POS that what good would bragging about it be?
The people I know wouldn't know the difference between a twin turbo and an oil filter.
I wanted my car to perform like stock until I was into boost, this kit does if for me. By ~2,000 I'm into boost (I don't know when I'm in full boost, I can't watch the boost and tach at the same time at that rate).
The front mount systems are going to give it to you how much sooner?
What started my infatuation with turbo's on my vette was a ride in an LPE 427 TT, the car was simply incredible. It had turbo lag as well.
Is it possible that you don't like the system because you can't brag about it, you feel that you have to explain off that the turbos are in the rear.
and I missed 4th adn teh clutch was at the point the car wouldn't move 2 passes later...03 Z06 with a hurst and the sts kit..
553/489 as well
Cajundude (MTI) 402, 800/800
HeavyChevy (MTI) 427, 750+
Steath (Cartek) 900+ rwhp, 388
Blowerboy (Vette Doctors) Who Knows, 402
Major Spray (Vette Doctors), 427
C6TT"something" Timing would help out his graph a lot.
FRC Tom 18 PSI 402
Garret 18 PSI 408
Silas (ECS) 20+ PSI 427
Myself (Synergy)conservative 10-15 psi on a fully built 427
There are three other cars/trucks I know of that are putting down 800+ with the STS setups.
I expect Major Spray and Silas to be putting down some really serious rwhp.. as those are single purpose (straight line) built cars. Soon they will calling the PRO 8, the PRO 7 and then the PRO 6.
I would suggest you check out the Drag Racing section.There are all bringing serious weapons to the track this season.
The mid to low 9 that I think you are referring to isn't an STS kit if memory serves - that was a one off rear mounted single turbo on a C5-R motor, tricked out AFR 225 heads, etc. Still very impressive, don't get me wrong.
Cheers,
Mark
FRC Tom 18 PSI 402
Garret 18 PSI 408
There were two more major observations, I did note in the Road & Track shootout with all the high hp cars (Viper included). A lot of people would be surprised. I will be back late, got to go.
The only real "running" STS car on the list is Cajundude.
The rest are custom one off pieces that have little or nothing to do with STS.
In addition, try comparing apples to apples before you "beat up" other products.
Phil
Phil
