crankcase evacuation
Old Jun 29, 2006 | 01:31 PM
James1098's Avatar
James1098
Default crankcase evacuation
Does anyone make a crankcase evac. kit that will work on a C5? I have a PTK kit on the car and I am presently using a small filter on the valve cover. I have a feeling that this is not going to work for very long. Under boost the filter gets saturated pretty quick.
Any ideas?
Old Jun 29, 2006 | 01:37 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Talk to Nick Yoskin... He has a slick catch can set up.
Old Jun 29, 2006 | 01:43 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Andy (A&A) sells a crankcase vacuum pump that is very You pick up some HP as well. It is pricey but kicks serious behind
Old Jun 29, 2006 | 03:53 PM
Warp Factor's Avatar
Warp Factor
Try the RoadRebel/ECS/TTi breather. If it works as planned, it shouldn't saturate and should return any oil it catches to the valve cover.
Old Jun 29, 2006 | 04:54 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I vented mine to the down pipe, Works great
Old Jun 29, 2006 | 05:16 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I always wondered if that approach would work well. I was concerned about two things:
clogging up the cats with oily vapor, and possible backpressure in the exhaust leading to exhaust gasses wanting to go back into the crankcase.
How did you work around these two issues?
Old Jun 29, 2006 | 05:50 PM
TaTommy888's Avatar
TaTommy888
I don't think his car is a daily driver. Check out his sig!!!
Tommy
Old Jun 29, 2006 | 05:54 PM
AVB's Avatar
AVB
If you want to just relocate the breather(s), just give it a -8 minimum at ea. cover.
Arnel
Old Jun 30, 2006 | 09:21 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I have one on my na stroker and it works well. I don't know if they have worked out the issue of finding a place to physically mount it in centifigul sc cars. Give 'em a call and tell them Mr. Lucky sent you (they'll only charge you double ).
Old Jun 30, 2006 | 11:34 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
thanks!!
james call me.
Old Jun 30, 2006 | 12:58 PM
FastCashDave
Cruise-In V Veteran
Tommy
I drive my car everyday, however I do not run cat's
So if you do run cat's hook it up after the cats
Old Jun 30, 2006 | 01:24 PM
TaTommy888's Avatar
TaTommy888
God bless!
Tommy
Old Jul 1, 2006 | 09:41 AM
Zrod's Avatar
Zrod
I read about A&A's ecav pump, but I don't think the location issue is resolved with power adder applications. Why not try a passive system. Run a zero crack pressure check valve in place of the pcv and a check valve at the valve cover breather (lets air out of the system, but not in). That way you can run the crankcase under vacuum without a pump.
Old Jul 4, 2006 | 02:10 PM
James1098's Avatar
James1098
Thanks everyone.
I appreciate your your help.
To crankcase evacuation
