Problem when stopping??
Here's the deal. I have a 6sp and everytme I come to a stop and put in the clutch it either dies or idles down to 100 0r 200 for a sec then catches itself and jumps back up to normal.
I have it now at my shop and they have gone over with a fine tooth comb and found nothing. They have replaced O2 sensors, checked the computer, gaskets, checked for vac leaks, removed and tested the injectors, etc.
The items I have in it are below in sig.
Anyone else run into this in the past, just looking for suggestions. Thanks.
Jeff
i think the unmetered air entering the intake is what causes this whole problem.....
just for beginners stick a bolt or something into that vacuum hose and see if it still does it
