02 fuel system issues-help!
Old Jul 5, 2006 | 01:41 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Default 02 fuel system issues-help!
Background 02 Z06, A&A P1SC LPE pump( I think it's a LPE?), 60lb inj, KB BAP- 600 rwhp-AFR rises from 11.1 to 12.1 from 6000 to 6600. I was under the assumption that the combination of pump, bap and large injecters would do the trick. Duty cycle is only 79%-should i just try to increase the pulse width? Fuel pump pressure is 58psi at idle and drops to around 53psi under boost. I verified the BAP is working at idle-if i join the wires at idle fuel pressure will go from 58 to 64 psi. I have yet to change the fuel filter this year although I do change them every year. Is there anything else I should look at-pump , regulater?
Old Jul 5, 2006 | 02:43 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
JMHO.. but if you're only seeing a 5psi drop at WOT, and that 5psi drop is consistent (e.g., once hot, it's always 5psi, not 5psi cold and then 15psi when hot)... then I would personally leave it as-is and tune around the pressure drop.
This is assuming that there is nothing mechanically "wrong", your fuel filter isn't causing the pressure drop, etc.
Old Jul 5, 2006 | 04:15 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
I'm going to change the fuel filter and work on the PE table-just like you and Andy from A&A have suggested. Right now it's something like 1.24 up to 6000 then 1.31 after that-I'll try something like 1.5 and see what happens. Thanks!
To 02 fuel system issues-help!
