they dont make an fbody maggy kit. it is a c5 kit that they installed on the fbody. so the answer is most likely yes.
unless they modded the _rap out of it...
make sure that u get the power steering res bracket that comes with the standard c5 kit...they should have it..fbody's use a diff location on the ps res
also the maggy res for the coolant should be included. it goes over the battery (if its intercooled) in the c5.
