Limitations?
Old Aug 16, 2006 | 09:58 AM
shanetr99's Avatar
shanetr99
Default Limitations?
I currently have a P1SC pushing 7 psi. with L.G. longtubes on a stock bottom end. Would anyone consider purchasing a cam and or heads combination, or would it be too much for the bottom end? Thanks for all replies. By the way, its a C5 vert.
Old Aug 16, 2006 | 10:27 AM
mdhmi's Avatar
mdhmi
I'd pulley it down. 7psi isn't enough.
After a couple years running 10-12 psi then pop in a forged short.
Old Aug 16, 2006 | 11:53 AM
goinpostol's Avatar
goinpostol
IMHO, I'd be a little concerned goin over 7psi on a stock bottom end. I just had a forged 346 installed due to the No. 7 ring land cracking I had a conservative tune in the car since it was my daily driver but things can still go wrong. I beleived that I was safe from harm at that level...I did put over 25,000 miles on that setup, and I do not drive conservatively at all , but I am also very mindful of detonation, etc. and don't know exactly why it happened, but it did. Of course it did provide me with a pretty damn good reason to get a forged bottom end, cam, springs and so on, so there was a bright side I am sure some have gone much further on stock bottom ends, but again I would caution you based only on my experience. Good luck with whatever you decide
Old Aug 16, 2006 | 12:35 PM
shanetr99's Avatar
shanetr99
So you would not advise installing a cam or heads?
Old Aug 16, 2006 | 12:37 PM
Laguna Blu's Avatar
Laguna Blu
What kind of power are you putting down? The reason that I ask is that I have a heads/cam 346, with a stock bottom end, making close to 400 RWHP and I just placed my order for a Procharger. After speaking with my tuner we concluded that it is wise to go with a 5 psi setup and conservative tune. I don't think that it would be wise to go higher than 500 RWHP, especially with my 3.90 gears & 3200 stall A4, which keeps the rev's up as it is. I have already upgraded springs and rockers so the top end should be O.K. But then again, you never know.
Old Aug 16, 2006 | 12:58 PM
shanetr99's Avatar
shanetr99
The dyno read 442 rwhp 475 torque. The reason for the low h.p. is from only taking it to 5500 r.p.m. Dont ask me why he stopped there. Anyway I'm guessing my true rwhp is around 490. Can I ask you how many r.p.m. you are running at 65 m.p.h.? Are you happy with your gear ratio and how much difference did you see in quarter mile times? Thanks.
Old Aug 16, 2006 | 01:13 PM
goinpostol's Avatar
goinpostol
If you were to install a quality h/c package, you stand to increase power quite a bit. My car put down 482rwhp on a Superflow dyno with a very conservative tune, and I still managed to come up with cracked ring lands. Could be that this is a one off occurence, but as I understand it my situation is pretty common. I would seiously consider a forged bottom end before looking any where else for power and at least you'll have a solid foundation to move forward from. Than you can look forward to fortifying your driveline
Old Aug 16, 2006 | 03:14 PM
Laguna Blu's Avatar
Laguna Blu
I'm not sure if you are an automatic or a manual but the difference is large as to what HP level is attainable. In any case all else being equal 442 RWHP is an awesome number for a '99 if your only mod is the blower. Just check my sig to see all the work necessary just to dyno an A4 at or near the 400 RWHP mark. As for forging the bottom end it is probably a good idea if you do that from the beginning but in my case, where the mods were done on an ongoing basis for the last 6 years, it just isn't practical. If I knew then what I know now I would have just built a 383 back then. Of course they are now building 402's so where would that have left me other than $15K poorer?
Old Aug 16, 2006 | 03:15 PM
Laguna Blu's Avatar
Laguna Blu
How much does a forged 346 run these days?
Old Aug 16, 2006 | 04:21 PM
mdhmi's Avatar
mdhmi
I think some of you guys are either getting crappy gas or crappy tunes. There is no excuse for blowing up in the sub 500 rwhp league. Just my .02.
Old Aug 16, 2006 | 09:05 PM
ProtoVette's Avatar
ProtoVette
Wow, I really can't believe you would lead someone to believe that 10-12 PSI on a stock engine is OK. (With a lot of luck) It may have worked for you and maybe some others, but you are living on the edge at that boost level on a stock engine, even with a good tune and gas. Ask the major LSx tuners what they recommend you safely run for boost level on a stock block. I believe it would be around 7 or 8 lbs. Heck, alot of people only run 12-14 lbs. once they forge the bottom end.
shanetr99,
I've done alot of reading on Fi for the Vettes over the years, and asked alot of questions, and done alot of research. Be careful with going with much more boost that what you are running now, unless you don't mind keeping in the back of your mind that a new motor might be just right aroung the corner.
Do your research, and talk to the reputable tuners to get the honest low-down on what they would recommend on what boost is considered safe.
To Limitations?
